smallembedded
esp32s3 burning rack
1. There is an automatic download circuit for CH340, and the chip uses CH340C, so you don’t need to use a crystal oscillator.
2. The power supply adopts DC-DC (because we are worried that it will require a current exceeding 1A and the LDO will generate too much heat) to ensure sufficient power supply.
3. All pins are lead out for easy use. Please refer to [Verified] ESP32S2 programming and debugging rack (compatible with ESP-12k lead out method. Each pin has a female header and a pin header interface, plus an unsoldered row. The solder pads facilitate the connection of various connectors.
v1.0 is currently under development and needs to be verified. If you have any questions, please give us guidance.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 06:57:27
  • Has anyone used evc or studied the asynchronous data synchronization problem of sqlce?
  • MSP430 reads and writes SD card
  • Interchangeable ESP12-E cards
  • Several Problems on Logarithmic Operation Circuit
  • Please help: UART
  • The PWM wave output by the microcontroller is unstable
