红水杯
SGM6232_buck 5v step-down module
SGM6232 is a current mode buck converter with internal power MOSFET switch. The switching frequency of the device is fixed at 1.4MHz, and the output voltage range is adjustable from 0.8V to 28V. It can efficiently deliver up to 2A of output load current over a wide input supply range of 4.5V to 38V with excellent load and line regulation response. The SGM6232 has a peak efficiency of 91% when operating efficiently. The regulator consumes less than 18μA of shutdown supply current. Protection features include circulating current limiting and thermal shutdown. The device also includes internal soft-start and externally adjustable soft-start features to limit inrush current and prevent overshoot of the output voltage. The SGM6232 comes in a green SOIC-8 (Exposed Pad) package, which also reduces the external components of the device to complete a 2A step-down DC/DC converter solution.
Module parameters and information:
1. 2A output current
2. 91% maximum efficiency
3. Power off current: 18μA (MAX)
4. 100mΩ internal power MOSFET switch
5. 1.4MHz fixed switching frequency
6. Undervoltage lockout
NO identifier Function illustrate
1 VIN/GND Power input terminal Support 12~38V power supply
2 OUT/GND Output 5V fixed output
3 EN Output enable terminal Floating enable output
Note: EN is left floating by default and is output directly after power-on. Users can also control the output through MCU;
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 17:26:08
  • How to use BOOT1 as IO after system reset?
  • Does anyone have information about mc9ks08ka2?
  • 08 IIC communication experience to obtain sensor data
  • The performance comparison of yaffs ubi file system
  • 430
  • vxworks adds 104 expansion board driver
