aytwartoofyoroo
Capacitive touch screen driver board based on CH554G chip solution
The CH554 chip is an enhanced E8051 core microcontroller compatible with the MCS51 instruction set. 79% of the instructions are single-byte single-cycle
Its instructions, on average, are 8½15 times faster than the standard MCS51. CH554 supports the highest system frequency of 24MHz, built-in ½ 16K program memory ROM and 256 bytes of internal iRAM and 1K bytes of on-chip xRAM. xRAM supports DMA direct memory access. CH554 has built-in ADC analog-to-digital conversion, touch button capacitance detection, 3 sets of timers and signal capture and PWM, dual asynchronous serial ports, SPI and other functional modules, and supports USB-Host host mode and USB-Device device mode.
This project uses the CH554G chip. After burning the program, it can drive the GT series capacitive screen.
The new C port leads to the ROM short interface and the screen wire flying wire solder joints. The wire sequence can be reordered by flying wires between the resistors. Double-sided panel, single-sided soldering chip, long strip shape.
The resistor and capacitor are packaged in 0603.
The win10 system can support 10-point touch.
PCB preview
The plate making files and burning tools are in the attachment
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 11:59:08
