aytwartoofyoroo
Infrared voice assistant
product description
        The infrared voice intelligent assistant based on Tuya Smart VWXR2-ES module has the functions of infrared learning and voice control of home appliances. Tuya IoT voice module VWXR2-ES is an IoT application WI-FI module equipped with voice wake-up & noise reduction algorithm developed based on XR872AT. It supports WLAN 802.11b/g/n+ARM Cotex-M4F and has built-in 416KB SRAM and 4MB PSRAM. Matching Tuya cloud voice skills + IoT platform, it can realize the voice portal empowerment of IoT products and well support low-cost online voice control terminal products. Support for external power amplifiers can better meet the needs of high-power operational amplifiers in some entertainment application scenarios.
With Tuya Smart's zero-code development, you can enjoy the voice smart assistant even if you don't know how to write code.
  • Built-in low-power 32-bit CPU, which can double as a processor, with a main frequency of up to 380MHz
  • Working voltage: 2.7-5.5V
  • Peripherals: 9*GPIO, 2*Uart, 2*ADC
  • Antenna support: onboard + optional ipex
  • Sampling rate: 16K/16bit
  • Voice input: built-in 2-channel audio ADC, which can directly simulate mic
  • Audio output: 1 way
  • Onboard audio amplifier: supports up to 2.6W
  • External power amplifier support: LOUT output, supports external power amplifier
  • Recommended wake-up distance: <=3m
  • Recommended working noise floor: <=60dbC
  • Default voice skills: weather, encyclopedia, calendar, calculator, idioms, translation, music content on demand - supports linear dual MIC, flexible and adjustable spacing (>40mm), flexible ID and MD structural design, easy to integrate.
  • Pin definition
    As shown in the figure below, VWXR2-ES requires an external MIC and speaker to complete voice interaction. We recommend the following processing methods for some peripherals required by the voice module by default:
    • Microphone (required): The pins of the mic are fixed and two external MICs must be connected. The MIC spacing is recommended to be 40-80mm. For specific mic specification recommendations, please consult Tuya technical personnel;
    • Speaker (optional): For customers who need sound interaction, VWXR2-ES has a built-in power amplifier and decoder, and an external 1-2.6W speaker can be connected according to needs. If a speaker is not needed, the following lighting interaction method can also be selected;
    • Voice status indicator light (optional): For customers who are cost-sensitive, have limited product space and cannot install speakers, or do not require audio feedback interaction, VWXR2-ES also supports two-color indicator light interaction. The user can not connect the speaker and prompt based on the indicator light feedback. The result of user voice control of IoT;
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 23:41:31
  • Main loop cannot run
  • Ubuntu Phone is coming
  • Moderator Chip Coin Rewards in October 2012!
  • About using DE1-SOC for future employment
  • Applications of MMA7455
  • Design considerations for a 500W Class D automotive subwoofer amplifier
