ohahaha
Type-C female to Type-C male socket, ip5306 charging
There is also no need to burn any programs!
Important note ❗:
1. Since the vertical type-c male socket is 24p and can only be welded with an air gun or a heating table, if you are a novice welder, it is recommended to buy a heating table for welding. The air gun is more expensive, not suitable for entry-level, and is inconvenient to carry. .
2. Supports flushing and releasing at the same time! Data can be transferred! It can be directly connected to a device with a USB to TTL chip for programming (in vernacular: such as the 8266 development board with a ch340 chip). It can also be used to charge a mobile phone and transfer data, but it does not support charging with too much current (such as a 6AGaN charger) ), because the ip5306 chip does not support it. The chip manual supports a maximum current of 2.1A, and overcurrent and overvoltage will automatically protect it.
3. After welding is completed, be sure to check! examine! Check!—— , I don’t want to see the tragic incident like my feedback that the power supply equipment burned down.
4. Since the power of the snowflake lamp is too low when the brightness is low and is close to no load, ip5306 will recognize that there is no device output and automatically sleep. Therefore, if used in battery mode, it is recommended not to turn it on too dark. It will not appear in the power supply mode. The problem.
About the shell
BOM download
Schematic_Type-C female to Type-C male socket, ip5306 charging_2022-10-07.pdf
SCH_Type-C female to Type-C male, ip5306 charging_2022-10-07.json
Base_2022-10-07.schdoc
PCB_PCB_ip5306_5v_charge and discharge integrated_2022-10-07.pdf
PCB_PCB_ip5306_5v_charge and discharge integrated_2022-10-07.json
PCB_ip5306_5v_charge and discharge integrated_2022-10-07.pcbdoc
Gerber_PCB_ip5306_5v_charge and discharge integrated.zip
60225
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 04:48:31
