supremeOne
stc 51 microcontroller fast programmer
A programmer for 51 microcontroller programming. It is small in size, uses typec interface, supports c2c cable, and has a power-off button (default is power on, press the button to power off, release the button to power on), in the project There is a download interface reserved on the PCB, so you can easily download the entire series of STC microcontrollers. Using spring probes and contact contacts, no wiring is required, and the pin arrangement is optimized to reduce the possibility of burning due to reverse connection when contacting the contacts.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 03:10:20
