JwzOa87VO
K100-K375s left hand digital open source
Applicable to the left-hand numeric area arrangement of the K100 mechanical keyboard. Since NUMLOCK comes with Page UP, Page Down, Home, End, Del and other keys after being turned on, the above independent key positions are deleted, and left-hand Backspace, left-hand =, and simultaneous increase are added. NumLock key.
In order to avoid the studs of the original shell as much as possible, some key positions and the direction of the shaft have been modified. It is recommended to completely cut off the studs between the Tab and the number area 8 and 9 on the original shell;
The positioning plate and sandwich cotton have been tested and are perfect. They are attached as engineering accessories and can be downloaded. It is recommended to use rigid positioning plates such as metal, carbon fiber, etc. It is not recommended to use acrylic, PC, and POM positioning plates because of insufficient support.
For details on the charging module link and voltage stabilizing module connection, please see the comment area of ​​Station B or downstairs.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 08:52:39
