DbbSqNanN
100M_diff_prob
Differential probes can be used to measure the differential voltage waveform at any two points in a circuit. The input impedance of both input terminals of the probe is very high and symmetrical, so it has less impact on the circuit and is less likely to introduce common mode interference. This probe can be connected to an oscilloscope via a coaxial cable; it is powered by USB 5V (for example, it can be powered from the oscilloscope). Appearance size is 75mm×20mm, transparent heat shrinkable tube can be used directly as the shell.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 23:57:26
