张小哥
2-inch flip-chip ring frame FPV ride-through machine
Design parameters:
2-inch circle flip-up, wheelbase 90 to allow ample space, changed to 87.5, can be used in ET85 rack
motor hole spacing ∮ 9*4 and ∮ 8*3
flight control supports 25.5mm and 20mm
image transmission supports 25.5mm ; 20mm, etc., you can modify the bottom plate file yourself, and you can update it later to support more support.
It is recommended to use a 2-4s450mah battery when changing to a circle.
Follow-up updates:
1. Improve the stl file, bare dogs and small peanuts must be added
2. Antenna base, The pig tail can be used at present; the 3D printed parts of T-shaped antenna and image transmission antenna will be improved in the future.
3. Battery buffer pad (cover the screw butt)
4. Bottom plate buffer pad
accessory list:
 1. Rack STL file, it is recommended to print it to a thickness of 3mm , you can use it directly
 2. Bottom plate file
 3. Camera bracket (dog mount will be upgraded later)
 4. Aluminum column It is recommended to use M2X22 (I will release the stl file when I have time, and the printing is good, it is enough)
. . . (For other 3D printing accessories, please see the comments section to add them later, so you can already fly)
There is no truth without pictures:
the effect after updating the drawings is as follows
90-2.stl
cam.stl
under.stl
2 rack.dxf
876cicle2.stl
85runcam.stl
ant85.stl
cam2.stl
antholl.stl
BOM download
PCB_PCB_2inch rack_2022-10-08.pdf
PCB_PCB_2inch rack_2022-10-08.json
PCB_2inch rack_2022-10-08.pcbdoc
Gerber_PCB_2inch rack_2022-10-08.zip
PCB_PCB_2-inch flip-chip ring frame FPV through machine_2022-10-08.pdf
PCB_PCB_2-inch flip-chip ring frame FPV through machine_2022-10-08.json
PCB_2-inch flip-chip ring frame FPV through machine_2022-10-08.pcbdoc
Gerber_PCB_2-inch flip-chip ring frame FPV through machine_2022-10-08.zip
60914
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 04:31:25
