toothache
ZYNQ-z7010 development board
Yes, this is a 6-layer board, so just take a look. Hahahaha. I don’t have any proofing
materials to ask customer service for.
Lite_Z7010 board.zip
BOM download
Schematic_ZYNQ-z7010 development board_2022-09-24.pdf
SCH_ZYNQ-z7010 development board_2022-09-24.json
ZYNQ-z7010 development board_2022-09-24.zip
61537
Heated control panel (verified)
Introduction: Everyone has been working on a heating table recently to make it easier to solder boards. I also made a small control board with the things I had on hand. I did not use PID control. It may be added later.
Everyone has recently been working on a heating table to make it easier to solder boards. I also made a small control board using what I had on hand. I did not use PID control, but may add it later.
The F401CCU6 used and the core board used are from WEACT. There are many pirated versions on the Internet. The genuine version seems to have been removed from the shelves. The address of the pirated version of
the heating plate is based on this project: Hilbert Curve of the Big Guy.
BOM_PCB_Heating plate copy_2022-05-27.csv
Heating plate (PID version).zip
BOM download
PCB_PCB_Heating plate copy_2022-09-24.pdf
PCB_PCB_Heating plate copy_2022-09-24.json
PCB_heating platecopy_2022-09-24.pcbdoc
Gerber_PCB_heating platecopy.zip
Schematic_Heating Controller (PID Control Updated)_2022-09-24.pdf
SCH_Heating Controller (PID Control Updated)_2022-09-24.json
Sheet_2_2022-09-24.schdoc
61538
FM5324GA charge and discharge module snowflake lamp base
Introduction: Battery charge and discharge module based on FM5324G, snowflake lamp base
FM5324GA charging and discharging module snowflake light base
overview
FM5324GA is an integrated power management IC used in mobile power supplies that integrates lithium battery charging management, battery boost output, battery power judgment and LED power indication.
FM5324GA is charged in a switching mode, including trickle charging, constant current charging and constant voltage charging. The float charging voltage accuracy can reach ±1% in the full temperature range, and has small charging current ripple and high charging efficiency. High advantages.
The DC-DC boost of FM5324GA can achieve an accuracy of ±1%, and can provide a boost conversion efficiency of more than 94%, extending battery life.
FM5324GA is equipped with 3 LED drive ports, which can drive 4 LEDs to display battery power. The chip has a built-in logic lock function to prevent the power indicator from being unstable.
FM5324G has multiple protection designs, including load overcurrent protection, soft start protection, input overvoltage protection, output short circuit protection, chip temperature protection, battery temperature protection, etc. At the same time, the chip port is designed with a high-performance ESD protection circuit, making the chip extremely reliable.
Introduction
1. There is nothing to introduce. Look at the pictures. The upper and lower boards are connected and powered through copper pillars.
The pictures show
F440BF086754AFB7E2447A5D8CF99C2D.jpgthat I have no money to buy batteries, so the batteries will be replenished in the near future.
FM5324GA.pdf
PCB_Battery Board_2022-11-05.pdf
BOM_Battery Board_Battery Board_2022-11-05.xlsx
Altium_FM5324GA charge and discharge module snowflake lamp base_2022-11-05.zip
PDF_FM5324GA charge and discharge module snowflake lamp base_2022-11-05.zip
61539
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 11:32:38
  • It turns out that only by suffering more losses can one grow.
  • Impedance matching concept
  • STM8S103K3 input capture problem
  • Love doesn't reward hard work
  • LM3S9B96 uip1.0 protocol stack?
  • How can I read the file?
