smallembedded
Solder paste extrusion
10cc solder flux extruder, just play with it and contribute to the open source cause.
PCB_Solder paste extrusion boost has not yet been tested. Using YX-9025AM, the voltage can be boosted to a maximum of 9v to increase the thrust.
This open source project is for DIY and learning purposes only. Any unauthorized sale for commercial purposes is prohibited.
lGqMrEqsP9BLfigd0Fx7Lqj1Zech3mi2NfPtl5s8.pngrJwIuiCEc229BLNPsCoO1BpgfqW0EkqZ5mOwQKij.png
Print.zip
15750bf22a0948f34cca423b23067bda.mp4
src.zip
extrusion.hex
BOM download
PCB_PCB_Solder paste extrusion boost FIX_2022-09-23.pdf
PCB_PCB_Solder paste extrusion boost FIX_2022-09-23.json
PCB_Solder paste extrusion boost FIX_2022-09-23.pcbdoc
Gerber_PCB_Solder paste extrusion boost FIX.zip
PCB_PCB_Solder paste extrusion boost_2022-09-23.pdf
PCB_PCB_Solder paste extrusion boost_2022-09-23.json
PCB_Solder paste extrusion boost_2022-09-23.pcbdoc
Gerber_PCB_Solder paste extrusion boost.zip
PCB_PCB_Solder paste extrusion_2022-09-23.pdf
PCB_PCB_Solder paste extrusion_2022-09-23.json
PCB_Solder paste extrusion_2022-09-23.pcbdoc
Gerber_PCB_Solder paste extrusion_2022-09-23.zip
Schematic_Solder paste extrusion_2022-09-23.pdf
SCH_Solder paste extrusion_2022-09-23.json
Sheet_1_2022-09-23.schdoc
61632
espWatch4.1
Introduction: Small watch made using ESP8266-12f
The battery can use a 650mah 802530 polymer lithium battery, which can be used for 24 hours when fully charged.
3D model, program source code and other information:
Link: https://pan.baidu.com/s/1Iq1TOih03PR6bcci5WxOjQ Extraction code: wzkj
Video: https://www.bilibili.com/video/BV1Lb4y147r6
The preview of the project file below is incorrect. Please click Open in Editor to view the correct information
BOM download
PCB_PCB_espWatch4.1_2022-09-23.pdf
PCB_PCB_espWatch4.1_2022-09-23.json
PCB_espWatch4.1_2022-09-23.pcbdoc
Gerber_PCB_espWatch4.1_2022-09-23.zip
Schematic_espWatch4.1_2022-09-23.pdf
SCH_espWatch4.1_2022-09-23.json
61633
ai infrared voice assistant
Introduction: Infrared AI voice assistant developed
Developed infrared ai voice assistant
BOM download
PCB_PCB_ai infrared voice assistant_2022-09-23.pdf
PCB_PCB_ai infrared voice assistant_2022-09-23.json
PCB_ai infrared voice assistant_2022-09-23.pcbdoc
Gerber_PCB_ai infrared voice assistant.zip
Schematic_ai infrared voice assistant_2022-09-23.pdf
SCH_ai infrared voice assistant_2022-09-23.json
Infrared voice assistant.Sch_2022-09-23.schdoc
61634
BM3451 startup level lithium battery protection board
Introduction: The lithium battery protection board based on BM3451 uses high-power MOS tubes to increase the output current.
The BM3451 series is a professional 3/4/5-cell rechargeable battery protection chip with high integration characteristics. It is suitable for power tools, electric
bicycles and UPS backup power supplies.
BM3451 realizes battery overcharge, over-discharge, discharge over-current,
short circuit, charging over-current, temperature protection and other protection functions by detecting the voltage, charge and discharge current, and ambient temperature of each battery, and adjusts overcharge, over-discharge, and temperature protection through external capacitors. Over-discharge and over-current protection delay.
BM3451 provides a battery capacity balancing function to eliminate the capacity differences of each battery in the battery pack and extend the life of the battery pack.
BM3451 can realize the cascading of multiple chips to protect 6 or more battery packs.
BOM download
PCB_PCB_BM3451 startup level lithium battery protection board_2022-09-23.pdf
PCB_PCB_BM3451 startup level lithium battery protection board_2022-09-23.json
PCB_BM3451 startup level lithium battery protection board_2022-09-23.pcbdoc
Gerber_PCB_BM3451 startup level lithium battery protection board.zip
Schematic_BM3451 startup level lithium battery protection board_2022-09-23.pdf
SCH_BM3451 startup level lithium battery protection board_2022-09-23.json
61635
SI4825 DSP mechanically tuned digital radio
Introduction: High-sensitivity AM SW FM radio with simple circuit and easy installation. Very suitable for DIY.
Mechanical Tuned AM/FM/SW Radio Receiver
Application
The Si4825 is an entry-level mechanically tuned digital CMOS AM/FM/SW radio receiver IC that integrates
all receiving functions from antenna input to audio output. The Si4825 expands Silicon Labs' family of multiband tuners
that
further . During production, the Si4825 requires
a simple application circuit and eliminates the need for all manual tuning components during production. This receiver consumes very little
power and operates on two AAA batteries, providing the analog radio market with the performance advantages of digital tuning.
Functional block diagram
 Supports global FM band
(64–109 MHz)
 Supports global AM band
(504–1750 kHz)
 Supports shortwave band
(2.3–28.5 MHz)
 No manual calibration required
 Mono audio output
 AM/FM/SW Regional band optional
∎ Enhanced FM/SW band coverage
∎ Automatic frequency control (AFC)
∎ Integrated LDO regulator
∎ 2.0 to 3.6 V supply voltage
∎ Supports wide-band ferrite rod antenna and air
loop antenna
∎ 16 Pin SOIC
 RoHS compliant
 Direct volume control
 Not EN55020 compliant*
*Note: For
consumer , use the Si483x.
∎ Desktop and Portable Radios
∎ Micro/Small Systems
∎ CD/DVD Players
∎ Speakers
∎ Modules
∎ Timer Radios
∎ Mini HiFi
∎ Entertainment Systems
si4825-a10-datasheet-cn.pdf
Si4825DEMO.pdf
59fc9b23d4b31afda6d7cc637f8de033.mp4
BOM download
PCB_PCB_SI4825 Radio_2022-09-23.pdf
PCB_PCB_SI4825 Radio_2022-09-23.json
Schematic_SI4825 DSP mechanically tuned digital radio_2022-09-23.pdf
SCH_SI4825 DSP mechanical tuning digital radio_2022-09-23.json
61636
si4844 mechanically tuned digital display full band radio
Introduction: stm32F103C8T6 Arduino For ARM si4844 mechanically tuned digital display full-band radio with super good sensitivity. The shortwave and FM antennas are only 37CM ​​and have basically the same effect as the Tecsun PL600.
   Using ST7565LCD liquid crystal display (screen of a certain Baoan Xinjia). There is no backlight, so a 4020RGB backlight is added to display the colorful backlight. Added DS3231 high-precision clock and DS18B20 temperature display. There is also a Bluetooth TFT card player designed by JL Jerry. Because the buttons are connected in parallel with the radio, there is a conflict. This function does not need to be used. Time setting: Press BASS- VoL- at the same time to enter the setting menu BASS+ year setting 18-60 years can only be increased upwards. The BAND+ month setting also increases by 1-12, the vol+ day setting also increases by 1-31, the bass-hour setting also increases by 0-24, the BAND-minute setting also increases by 0-59, and the VOL-second setting also increases by 0- 59. After setting, press the RGB LED key to save the settings, so that the settings can be accurate to the second. Press SET key to exit setting. I’ll talk about other functions when I have time. Due to PCB space limitations, the AM antenna is too close to the CPU to cause high interference. Improvements will be made in the future (adjusting component locations or adding shielding covers).
   Attached are two boards with PCB proof files. As well as SI4844B20 Chinese manual and official PCB design specification DEMO.
   Program compilation instructions: To build the Arfuino For STM platform, you need to first download the MAPLE firmware for STM32F103C8T6 to support Arduino software. Specifically Baidu. The attachment comes with an Arduino program. Libraries used: Please download in the Arduino software. PU2CLRSI4844, U8G2, DS3231. The program is a bit messy, just a novice.
Gerber_SI488 radio board.zip
Gerber_SI4888 radio download.zip
si4840-44-a10-datasheet-cn.pdf
Si484x-DEMO-198306.pdf
VID_20220305_085323.mp4
VID_20220304_195818 (3).mp4
SI4844_ST7565_220308.rar
Gerber_PCB_SI4844 front panel.zip
Tuning wheel+button.rar
BOM download
PCB_PCB_si4844 Mechanically tuned digital display full-band radio_2_2022-09-23.pdf
PCB_PCB_si4844 Mechanical Tuning Digital Display Full Band Radio_2_2022-09-23.json
PCB_si4844 Mechanical Tuning Digital Display Full Band Radio_2_2022-09-23.pcbdoc
Gerber_PCB_si4844 mechanically tuned digital display full-band radio_2.zip
Schematic_si4844 mechanically tuned digital display full-band radio_2022-09-23.pdf
SCH_si4844 Mechanically tuned digital display full-band radio_2022-09-23.json
61637
Rev.GP Panda Panda PCB cover
Introduction: GP Panda Cover
Rev.GP Panda Panda PCB cover (just make the cover, ignore the gameplay below)
2 ways to play.
The first is to return only the upgraded battery.
You can use it as a cover only, or you can upgrade the battery by yourself. The space reserved for the battery is 4cm thick.
Upgrade the original 40mAh button battery and replace it with a 450mAh lithium battery to upgrade the battery life. The current test is that it can work continuously for 48 hours.
The second option is to add the small orange plate
accessories: screws-nuts-switch-battery (optional)
accessories purchase The reference pictures are as follows:
The main film begins: Please enjoy
Gerber_PCB_Rev.GP Panda simulation card set_3_2022-08-15.zip
QQ short video 20220821124453.mp4
BOM download
PCB_GP Panda Panda PCB cover-Bluetooth version_2022-09-23.pdf
PCB_GP Panda Panda PCB cover-Bluetooth version_2022-09-23.json
GP Panda PCB cover-Bluetooth version_2022-09-23.pcbdoc
Gerber_GP Panda Panda PCB cover-Bluetooth version_2022-09-23.zip
PCB_GP Panda upgraded version_2022-09-23.pdf
PCB_GP Panda upgraded version_2022-09-23.json
GP Panda upgraded version_2022-09-23.pcbdoc
Gerber_GP Panda upgraded version_2022-09-23.zip
61638
Flash circuit board-open source
Introduction: Flash circuit practice
Flash circuit
BOM download
PCB_PCB_1_2022-09-23.pdf
PCB_PCB_1_2022-09-23.json
PCB_1_2022-09-23.pcbdoc
Gerber_PCB_1_2022-09-23.zip
Schematic_Flash circuit board-open source_2022-09-23.pdf
SCH_Flash circuit board-open source_2022-09-23.json
SHEET_2022-09-23.schdoc
61639
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 04:54:00
