通通
PCB pendant key chain
You can also design small pendants for fun. You can also make prototypes and make changes, and
click "Open with Editor" in the upper right corner of the window.
You can also select the specified project under this project to open
some pendants separately. Single and double-sided versions are
also available. It means that those pendants support glass fiber/aluminum-based PCB.
There is no need to check DRC.
When placing an order, the thickness is recommended to be 1.6mm.
If the silk screen layer inside the PCB contains the words JLCJLCJLCJLC,
please select the designated location and add the customer number when placing the order.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-06-30 09:21:54
