BMbVb
ra0733—Smart humidifier
                                            Overall rendering
(due to insufficient DIY time, the upper humidifier shell was modified from ready-made DIY, and cannot be used for commercial purposes)
1. Display temperature and humidity through OLED, and change modes with buttons.
2. Mode 1 changes the RGB color according to different humidity. The RGB color of the humidity difference can be changed through software and can be burned through typec (for example, very wet is dark blue, moderate is green).
3. Mode 2 changes the RGB color according to different temperatures. The temperature difference RGB color can be changed through software and can be burned through typec (for example, very hot is red, very cold is blue).
4. Mode 3 customized RGB light show.
5. Set a humidity value (currently set to 80%), and turn off the spray when the humidity is reached.
6. Automatically shut down the spray when there is water shortage.
7. A small fan or light can be connected externally, and the speed can be adjusted through the knob.
        PCB finished product display
        peripheral link diagram
        assembly diagram
        schematic diagram
        PCB
        3D display
part code display
mode 1: change RGB color every 20% humidity interval.
Mode 2: Temperature<10, RGB blue, 10
Mode 3: Custom RGB, RGB can be changed by programming.
Liquid level detection, high humidity detection, wind speed adjustment
                                          (better DIY appearance and more complete function videos will be released in the future)
        video effects, the code has been uploaded
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 04:31:22
