ghaytweyhtoo
D-LED-B-GEVK: Dual LED Ballast Daughter Evaluation Board
D-LED-B-GEVK: Dual LED Ballast Shield Evaluation Board
The dual LED ballast shield evaluation board features the NCV78763, a single-chip, high-efficiency smart power ballast and dual LED driver designed for high-current LEDs, providing a complete solution to drive two strings of lights up to 60 V through two internal independent buck switch channel outputs, and the PCA9655E provides 16-bit general-purpose parallel input and output (GPIO) expansion through the I2C bus and SMBus. Due to SPI programmability, a single hardware setup can support multiple system configurations, enabling a flexible platform solution. Required power supply: Digi-Key Mouser
The Dual LED Ballast Shield Evaluation Board utilizes the NCV78763, a single chip, highly efficient smart power ballast and dual LED driver designed for high current LEDs that provides the complete solution to drive two strings up to 60 V, by means of two internal independent switch buck channel outputs with the PCA9655E to provide 16 bits of General Purpose parallel Input and Output (GPIO) expansion through the I2C-bus and SMBus. to the SPI programmability, one single hardware setup can support multiple system configurations for a flexible platform solution approach.
Power Supply needed:Digi-Key Mouser
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 19:31:33
