桂花蒸
NCD83591AS-GEVB: NCD83591 60V, three-phase gate driver demonstration board
NCD83591AS-GEVB: NCD83591 60V, 3-Phase Gate Driver Demo Board
The demo board supports the evaluation of the 3-Phase Gate Driver, NCD83591. The NCD83591 is an easy to use gate driver optimized for low BOM cost in a 4x4mm QFN28 package.
The wide operating voltage range (60V max) of this device makes it ideal for industrial and commercial applications.
Features and Applications
Operation from 5 V to 60 V Supply Voltage with Tolerance from 4 V
to 70 V
Constant Current Drive of Power FET, Configurable from 5 mA to
250 mA (16 Settings by Input Level to VDRV Pin)
Internally Generated Gate Drive Supply Voltages
Gate Sensing for Cross Conduction Protection and Optimized Dead
Time
Embedded High GBW General Purpose Amplifier (Intended for
Current Sensing and Externally Configurable)
Embedded Charge Pump Function Allowing DC Static Drive
Under Voltage Lock Out on VM, VGL, and VGH−VM
5 V/3.3 V Compatible 6 Input Control Plus Enable
Up to 30 kHz Motor PWM with Individual Six Gate Control Mode
4 kV HBM and 1 kV CDM ESD Protection
Power Tools
Light Mobility (E−Bikes, E−scooters, Hoverboards)
Automated Guided Robots
Industrial Actuators and Cobots
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 10:13:40
