ohahaha
NCP1034BCK5VGEVB: High Voltage PWM Controller Evaluation Board
The NCP1034 is a high voltage PWM controller designed for high performance synchronous Buck DC-DC applications. The NCP1034 drives a pair of external N-MOSFETs using a programmable switching frequency up to 500 kHz which allows flexibility to tune the operation of the IC to meet system level requirements. An external synchronization feature allows the simplification of system level filter design. The output voltage can be precisely regulated using the internal 1.25 V reference voltage for low voltage applications. Protections such as under voltage lockout and hiccup current limit are provided to give required system level security in the event of a fault.
Features and Applications
Input voltage up to 100V
1.25 V +/-1.5% feedback voltage across temperature
External Frequency Synchronization
Programmable switching frequency up to 500 kHz
2 A Output Drive Capability
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 07:41:25
  • Have you used TLV5630 chip?
  • A beginner asks for advice on type conversion?
  • Trigger event of stm32's rtc alarm interrupt
  • Temperature transmitter hardware framework and schematic diagram
  • Zigbee network registration problem
  • Free DSP Example Video Tutorial Download
