黄土马家
NCP4306LLC60GEVB: NCP4306 High Efficiency SR Evaluation Board with 60V MosFET for LLC Applications
NCP4306LLC60GEVB: NCP4306 high efficiency SR evaluation board for LLC application, with 60V MosFET
The The NCP4306FLY100GEVB Evaluation Board is high performance driver tailored to control a synchronous rectification MOSFET in switch mode power supplies. Thanks to its high performance drivers and versatility, it can be used in various topologies such as DCM or CCM flyback, quasi resonant flyback, forward and half bridge resonant LLC. The combination of externally or fixed adjustable minimum off-time and on-time blanking periods helps to fight the ringing induced by the PCB layout and other parasitic elements. A reliable and noise less operation of the SR system is insured due to the Self Synchronization feature. The NCP4306 also utilizes Kelvin connection of the driver to the MOSFET to achieve high efficiency operation at full load and utilizes a light load detection architecture to achieve high efficiency at light load. The precise turn−off threshold, extremely low turn−off delay time and high sink current capability of the driver allow the maximum synchronous rectification MOSFET conduction time and enables maximum SMPS efficiency. The high accuracy driver and 5 V gate clamp enables the use of GaN MOSFETs.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-17 00:08:34
  • ADF4158 write timing cannot respond
  • Lwip raw api application problem without operating system
  • Quartus adds phase-locked loop problem
  • mega16 assembly
  • Newcomer Registration
  • [MsgOS] Make the system run
