宋元浩
NCP171AMX170165TCGEVB: NCP171: LDO regulator, ultra-low 50nA Iq, with dual supply mode, 80mA evaluation board
NCP171AMX170165TCGEVB: NCP171: LDO Regulator, Ultra-Low 50nA Iq, with Dual Power Mode, 80mA Eval board
The NCP171 is a Dual mode LDO offering up to 80 mA in Active Mode and as low as 50 nA of Iq in Low Power Mode. The Dual Mode function is selectable with the ECO pin allowing for dynamic switching between Active and Low Power Modes, ideal in long life battery powered wireless applications. The output Voltage in Low Power mode can be lowered by an internally factory programmed value ranging 50 mV, 100 mV, 150 mV or 200 mV with respect to the nominal output voltage in Active Mode.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 14:28:58
  • Raw-OS and micro raw-OS development repositories
  • Issues with layout implementation and process implementation
  • [RVB2601 Creative Application Development] VI. Sound Playback Test of RVB2601
  • Asynchronous time domain data processing
  • Peak detection circuit
  • MCU AD digital-analog isolation solution
