toothache
NCP3064DFBCKGEVB: DFN8 Buck Demonstration Evaluation Board
The NCP3064 device supports buck configuration with a wide input voltage range from 3.0V to 40.0V. The NCP3064 is a low-cost converter that supports 1.5A current with a maximum duty cycle of 85.7%. An on/off function allows the device to be switched to a low-power mode. 7%. The ON/OFF function allows turn the device to low consumption mode. Size: 45mm x 28mm x 14mm Features and Applications Features Input Voltage Range from 3.0 V to 40 V Logic Level Shutdown Capability Low Power Standby Mode, Typical 100 uA Output Switch Current to 1.5 A Adjustable Output Voltage Range 150 kHz Frequency Operation Precision 2% Reference Internal Thermal Shutdown Protection Cycle-by-Cycle Current Limit NCV Prefix Suitable for Automotive and Other Applications Requiring Field and Control Changes These are Lead Free Devices
The NCP3064 device supports a buck configuration with a wide input voltage range from 3.0V to 40.0V. The NCP3064 is a low cost converter that supports a pcurrent of 1.5A with a maximum duty cycle of 85.7%. The ON/OFF function allows turn the device to low consumption mode. Size: 45mm x 28mm x 14mm
CyclebyCycle Current Limiting
NCV Prefix for Automotive and Other Applications Requiring Site and Control Changes
These are PbFree Devices
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 03:19:37
