ghaytweyhtoo
NCP57152MNADGEVB: 1.5 A Adjustable VLDO Regulator Demonstration Evaluation Board
The NCP57152 is a high accuracy, very low dropout (VLDO), low minimum input voltage and low ground current positive voltage regulator capable of providing over 1.5 A of output current with a typical dropout voltage of 330 mV at 1.5 A load current and input voltage of 1.8 V and above. The device is stable when using ceramic output capacitors. The device can withstand a maximum input voltage of up to 18 V. Internal protection features include output current limiting, built-in thermal shutdown and reverse output current protection. Logic level enable and error flag pins are provided. The NCP57152 is an adjustable voltage device available in D2PAK-5 and DFN8 packages.
The NCP57152 is a high precision, very low dropout (VLDO), low minimum input voltage and low ground current positive voltage regulator that is capable of providing an output current in excess of 1.5 A with a typical dropout voltage of 330 mV at 1.5 A load current and input voltage from 1.8 V and up. The device is stable with ceramic output capacitors. The device can withstand up to 18 V max input voltage. Internal protection features consist of output current limiting, built-in thermal shutdown and reverse output current protection. Logic level enable and error flag pins are available. The NCP57152 is an Adjustable Voltage device and is available in D2PAK-5 and DFN8 packages.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 14:29:04
