王达业
NCP781BMN050TAGEVB: NCP781 5V High Voltage Tolerant Linear Regulator with Enable Function Demonstration Board
NCP781BMN050TAGEVB: NCP781 5V Very High Voltage Tolerant Linear Regulator with Enable Function Demoboard
The demoboard supports the very high−voltage tolerant linear regulator NCP781 in DFN6 3.3 x 3.3 package with fixed output voltage 5.0 V. The ENABLE function allows turn the device to low consumption mode with quiescent current about 1 uA. The device is able to withstand continuous DC or transient input voltages up to 150 V. The small output capacitor 0.1 uF is sufficient for stable behavior and allows smaller PCB design at space constraining applications.
Size: 50mm x 50mm x 19mm
Features and Applications
Ideal for Harsh Environments
Thermal Shutdown and Current Limit Protection
Available in Thermally Enhanced DFN6 3.3 x 3.3, 0.65P Package
Very High PSRR: 83/56 dB@1/100 kHz
Standby Current: 1 uA
Very Low Quiescent Current of Typ. 25 uA
Output Voltage Versions:
Fixed 5.0 V
Wide Input Voltage Range: 6 V to 150 V
±2.5% Accuracy at Room Temperature
Stable with a 0.1 uF Ceramic Output Capacitor
These are Pb−free Devices
Telecom, Industrial
Bias Power Supplies, Led Lighting
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:31:23
