兰博
NCV47821PAAJGEVB: 3.3 V to 20 V Adjustable Dual LDO with Adjustable Current Limit and Diagnostics Evaluation Board
NCV47821PAAJGEVB: 3.3 V to 20 V Adjustable Dual LDO with Adjustable Current Limit and Diagnostic Features Evaluation Board
The NCV47821PAAJGEVB Evaluation Board is designed to effectively evaluate the NCV47821, which is a dual channel LDO regulator with 200 mA per channel is designed for use in harsh automotive environments. The device has a high peak input voltage tolerance and reverse input voltage, reverse bias, over-current and over-temperature protections. The integrated current sense feature (adjustable by resistor connected to CSO pin for each channel) provides diagnosis and system protection functionality. The CSO pin output current creates voltage drop across CSO resistor which is proportional to output current of each channel. Extended diagnostic features in OFF state are also available and controlled by dedicated input and output pins.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 12:45:48
