supremeOne
NCV8675DS50GEVB: Precision 5 V fixed output evaluation board
NCV8675DS50GEVB:  Precision 5 V Fixed Output Evaluation Board
The NCV8675 is a precision 5.0 V fixed output, low dropout integrated voltage regulator with an output current capability of 350 mA. Careful management of light load current consumption, combined with a low leakage process, achieve a typical quiescent ground current of 34 uA. NCV8675 is pin for pin compatible with NCV4275 and it could replace this part when very low quiescent current is required. The output voltage is accurate within +/-2.0%, and maximum dropout voltage is 600 mV at full rated load current. It is internally protected against input transients, input supply reversal, output overcurrent faults, and excess die temperature. No external components are required to enable these features.
Features and Applications
+/-2.0% Output Accuracy, Over Full Temperature Range
34 uA Maximum Quiescent Current at Iout = 100 uA, up to 85 C
600 mV Maximum Dropout Voltage at 350 mA Load Current
Wide Input Voltage Operating Range of 5.5 V to 45 V
Internal Fault Protection
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-30 19:22:56
  • Question about 28335 algorithm time
  • ucos-iii startup problem
  • Launchpad430--UART written for you
  • About the power consumption of MSP430
  • Can someone help me look at the code?
  • How to make a PCB package
