newrudeman
NCV890203MWGEVB: 2A 2MHz Automotive Switching Buck Regulator Evaluation Board with Reset and Adjustable Delay
NCV890203MWGEVB: 2A 2MHz Automotive Switching Buck Regulator with Reset and Adjustable Delay Evaluation Board
Evaluation Board for the NCV890203, which is a fixed−frequency, monolithic, Buck switching regulator intended for Automotive, battery−connected applications that must operate with up to a 36 V input supply. The regulator is suitable for systems with low noise and small form factor requirements often encountered in automotive driver information systems. The NCV890203 is capable of converting the typical 4.5 V to 18 V automotive input voltage range to outputs as low as 3.3 V at a constant switching frequency above the sensitive AM band, eliminating the need for costly filters and EMI countermeasures. A Reset pin signals when the output is in regulation, and a pin is provided to adjust the delay before the RSTB signal goes high. The NCV890203 also provides several protection features expected in Automotive power supply systems such as current limit, short circuit protection, and thermal shutdown. In addition, the high switching frequency produces low output voltage ripple even when using small inductor values and an all−ceramic output filter capacitor − forming a space−efficient switching regulator solution.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-12 16:30:45
