走马观花
STR-NCV7685-REAR-GEVK: Strata-enabled programmable animated taillight platform
STR-NCV7685-REAR-GEVK: Strata enabled programmable animated rear lighting platform
STR-NCV7685-REAR-GEVK is an evaluation board for vehicle rear lighting application with remote communication via BLE which features the linear LED current driver NCV7685 and the industry?s lowest power consumption Bluetooth® 5 SoC, RSL10 SiP. 6pcs. NCV7685 are mounted to drive total 72 LED nodes to implement predefined animations with both configurable parameters and customized patterns, all the settings and circuit monitoring can be accessed by Strata. In addition, Strata provides all the documents including user manual, manufacturing files, firmware codes which could dramatically accelerate your design work.
See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
Features and Applications
Strata GUI and Apps available
Pre-defined Animations with configurable parameters and customized pattern
Floating Address for easy maintenance
High flash rate of Animation
6*NCV7685 to drive 72 LED nodes
NCV7685 - 12 Common Current Programmable Sources up to 60 mA
Detection and protection against open load and under−voltage
Over temperature detection and protection
RSL10 SiP - Bluetooth® 5 Certified with LE 2M PHY Support
Arm Cortex−M3 Processor and LPDSP32
Fully integrated antenna and all passive components
Entry Level LED Taillights
High End Pixelized LED Taillight with Full Animation Capabilities
Turn Signal
Dashboard Applications
In Vehicle Network
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-16 04:29:13
  • 【American Classics】Series of Textbooks
  • MSP430 - Key interrupt control small light flip
  • High-power LED lamp design experience sharing
  • About Hall speed measurement
  • Wince device is identified as USB disk problem (continued)
  • About gprsdtu,sim900a tcp transmission problem
