supremeOne
NCV896530GEVB: fixed frequency dual adjustable output 1.6A, 3.3V, evaluation board
NCV896530GEVB: Fixed Frequency Dual Adjustable Output 1.6A, 3.3V, Evaluation Board
The NCV896530EVB evaluation board provides an opportunity to evaluate the NCV896530 in a convenient form factor with an adjustable output. The board contains four potentiometers, allowing the user to coarsely and finely adjust each output independently. The outputs are capability of providing up to 1 A each and 1.6 A total. The two enable pins allow each switcher to be used independently, while the SYNC pin allows you to synchronize the oscillator to an external clock up to 2.7 MHz and the POR pin reports the state of the outputs.
Features and Applications
Dual 0.9 V – 3.3 V Adjustable Output
1 A Output Current Per Channel, 1.6 A Total
Fixed Frequency Operation at 2.1 MHz
2.7 V − 5.5 V Input Voltage Range
External Clock Synchronization up to 2.7 MHz
Output Monitoring
Automotive Grade
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 09:29:56
