太白金星
1.6kW 48V output telecommunications equipment power supply
This reference design provides design guidance, data and other content for a 1.6kW 48V output power supply using semi-bridgeless PFC and isolated phase-shifted full-bridge DC-DC converters. Explain the input voltage AC 90V to 264V output voltage DC 48V output power 0.8kW (AC 100V system input), 1.6kW (AC 200V system input) circuit topology semi-bridgeless PFC, phase-shifted full bridge + synchronous rectification, output Oring circuit characteristics Appearance photos of 1.6kW 48V output telecommunications equipment power supply. 1 rack high-efficiency high-power output power supply. Output voltage 48V. Total efficiency: 94.6% (Vin=230V, under 100% load condition). Overall dimensions: 318mm×127mm×43mm (including Substrate below the PCB and top plate above the heat sink) Provide appropriate power devices (MOSFETs and SiC diodes) and optocouplers
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-02 09:43:52
