CQM8ngD
Quanta HSEC array card adapter board
The Xianyu hearse card is too outrageous, the spray tin plate costs 60, so I made one myself. JLC7628 is laminated and you can use coupons.
The small board on top is cut off with a small grinding wheel, inserted into the corresponding hole, and then soldered. It is recommended to use medium and low temperature tin wire and add more flux.
In addition, this position in the picture will block the studs, which need to be polished before welding.
It is recommended to use 12mm high nylon posts and m3 nylon screws with m3 holes to fix the array card.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 22:55:19
  • 【I contribute to the XILINX Resource Center】ch FPGA resource integration
  • A strange problem writing to the database
  • How to judge the stability of a sensor?
  • Differences between BSL and JTAG
  • About the crystal oscillator problem of LM3S3749
  • T2W Capacitor,trimming potentiometer
