sigma
IP5389-4.0
Please read the following text instructions and chip manual carefully before asking any questions! ! !
Modification based on the V2.0 version "IP5389+BM3451 two-way 100-watt fast charging mobile power supply solution" (click on the text to jump)
Updated features:
more reasonable layout,
higher original component density,
perfectly adapted aluminum alloy shell
, smaller PCB size ( Size only 80*25mm)
Better heat dissipation design (all heating devices are on the back and can be dissipated through thermal pads and casing)
Integrated 4 string protection board
The maximum input and output power is 100W
Only supports 4 strings of ternary lithium batteries (TYP 3.7V)
Some chips of the mobile power supply are IP5389_BZ
protection board and some chips are BM3451TNDC_T28A
digital tube link (click the text to jump) All the options in the link can be used, regardless of common cathode and common anode
PW6206-5.0 link (click the text to jump) 5V, SOT23 package
BM3451 link (Click the text to jump)
IP5389 chip link (Click the text to jump)
RUH30J51M link (Click the text to jump)
RU3030M2 link (Click the text to jump)
IP5389-NTC (NTC2) link (Click the text to jump) B3380 10K 1% Length 70mm (10 pieces)
BM3451-NTC (NTC1) link (click the text to jump) B3950 10K 1% length 70mm (10 pieces)
Aluminum alloy shell purchase link (click the text to jump) If you need to customize 132-135mm length,
you only need one, you can send me a private message (PS: Someone made too many orders to meet the minimum order quantity, I won’t tell who it is)
Attention! ! ! The battery terminal current is relatively large when the input and output are high. Pay attention to the battery selection (LG M50T 21700 OR Samsung 50S is recommended). I will not go into the introduction of the chip. If you need it, you can look at the previous project. The 5-string version is completed
directly as shown in the picture above .
Will be updated next week
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 05:54:03
