dii2Hu
ESP8266 4-way control socket connected to HASS
ESP8266-12F is used as the core to make a 4-way socket strip with 4 independent buttons.
It is used to connect to HASS.
After the ESPHome plug-in recognizes the firmware with ESPHome, the code can be upgraded via wifi.
The 4-way buttons independently control the 4-way output and can set the main switch. This production is not used for the time being, so the relevant code is not written.
1m: # Enable wifi hotspot (captive portal) ap: ssid: "************" password: "***********" web_server: port: config (optional) platform: gpio name: "配置1" id: kaiguan1 pin: number: 16 ip: tcp : port: config (optional) tcp: port: config/opt: -p esp: -m: power: -s ap: -m: power: -s ap: -m: power: -s ap: -m: power: -s ap: -m: power
:   -s ap : -m: power: -s ap: -m: power: -s ap: -m: power: -s ap   : -m :     power   : -s ap   : -m   : power: -s ap: -m: power: -s ap:   -m   : power: -s ap: -m:     power   :     -s     ap     :   -m   : power     :       -s       inverted: no   - platform: gpio     name: "Switch 2"     id: kaiguan2         pin:       number: 14       inverted: no   - platform: gpio     name: "Switch 3"     id: kaiguan3         pin:       number: 12       inverted: no   - platform: gpio     name: "Switch 4"     id: kaiguan4     pin:       number: 13       inverted: no binary_sensor:   - platform: gpio     pin:       number: 5       mode: INPUT_PULLUP inverted       : True     name: "Self-reset switch 1"     on_press:       - switch.toggle: kaiguan1   - platform: gpio     pin:       number: 4       mode: INPUT_PULLUP       inverted: True     name: "Self-reset switch 2"     on_press:       - switch.toggle: kaiguan2   - platform: gpio     pin:       number: 0       mode: INPUT_PULLUP       inverted: True     name: "Self-reset switch 3"     on_press:       - switch.toggle: kaiguan3   - platform: gpio     pin:       number: 2       mode: INPUT_PULLUP       inverted: True     name: "Self-reset switch 4"     on_press:       - switch.toggle: kaiguan4
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 00:14:04
