走马观花
CP2102 to serial port
CP2102 is a USB to UART bridge circuit that completes the conversion of USB data and UART data. The circuit connection is simple and the data transmission is reliable. It converts the serial data of the lower computer into USB data format to facilitate data communication. By running the chip on the upper computer The driver can read and write USB data through a simple serial port. It is easy to program and flexible to operate.
Brief description of the USB to serial communication module:
1. Dimensions: full length mm 42 mm wide 20 mm high 10 mm
2. Main chip: CP2102
3. Working voltage: USB power supply
USB to serial communication module circuit features:
1. With power indicator.
2. The input port is directly connected to the computer USB port.
3. Use a wide range of baud rates.
4. Data transmission is reliable.
5. Flexible operation.
6. Driver installation is required.
7. Only three wires are needed to directly connect the microcontroller: RXD, TXD, and GND.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:06:34
