张三叔
SSD2828 (RGB to MIPI function implementation)
The internal structure of the SSD2828 chip includes RGB input port, MIPI output port, control logic and SPI interface. When the RGB signal is input to the RGB input port, the control logic processes and converts the signal, and then outputs the converted MIPI signal through the MIPI output port. In this process, the N76e003 chip communicates with the SSD2828 chip through SPI communication to control and configure the working parameters of the SSD2828 chip, including resolution, refresh rate, color mode, etc.
The SSD2828 chip supports a wide range of resolutions and can meet the needs of different devices. By configuring the resolution parameters via SPI communication, we can adapt the image signals to different displays. In addition, the SSD2828 chip also supports the conversion of multiple color modes, including RGB888, RGB666 and RGB565. By configuring the control register, we can select the appropriate color mode so that the image presents the best effect on the display screen.
Currently only firmware is provided, other firmware will be updated gradually.............................
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-27 12:16:13
