gIKHW9LkJz
NS magnetic field detection tool
Principle introduction: This solution uses the KTH1604 dual-output Hall sensor. The sensor has two output pins. After the S pole magnetic field reaches the threshold, the output of pin 1 changes from high level to low level. After the N pole is felt, After the magnetic field reaches the threshold, the output of pin 3 changes from high level to low level. When the sensor senses magnetic fields of different polarities, the corresponding pin output potential jumps, thereby achieving the function of detecting the N and S pole magnetic fields.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 02:30:31
  • Problem defining address variables
  • Which expert is willing to help?
  • Altium Designer 10: From Getting Started to Mastering Operations (final version on November 2, 2014)
  • mplayer cannot play videos after porting
  • Onpaint() flickering issue in EVC
  • EMC rectification case sharing
