红水杯
DER-958 - 70 W High Line Input Voltage Power Supply for Wall Outlets with USB Type-C/A Ports using InnoSwitch4-CZ PowiGaN and ClampZero
DER-958 - 70 W High-Line Input Voltage Power Supply for Wall Outlets with USB Type-C/A Ports Using InnoSwitch4-CZ PowiGaN and ClampZero
70 W power supply for wall outlets with high-power USB Type-C/A ports using PowiGaN-based InnoSwitch4-CZ (INN4074C-H182) and ClampZero (CPZ1062M), optimized for 180 VAC to 265 VAC operation Operates down to 100 VAC to accommodate unstable supply voltages 5V/6.5A, 9V/5A, 15V/4A, 20V/3.5A outputs >94.5% full load efficiency at nominal input <20 mW system no-load input power Zero voltage switching in CCM and DCM operation Low component count (<60)70 W power supply for wall outlets with high-power USB Type-C/A ports using PowiGaN-based InnoSwitch4-CZ (INN4074C-H182) and ClampZero (CPZ1062M), optimized for 180 VAC to 265 VAC operationCan operate down to 100 VAC to accommodate unstable mains voltage5 V / 6.5 A, 9 V / 5 A, 15 V / 4 A, 20 V / 3.5 A outputs>94.5% full load efficiency at nominal input<20 mW system no-load input powerZero voltage switching in both CCM and DCM operating conditionsLow components count (<6 0)
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-08 13:33:53
