手可摘棉花
Open ECU control module
Open electronic control modules suitable for various vehicles and internal combustion engine types, which the author continues to update. The electrical systems and electronics of all Volvo cars with the common chassis P2 between 1998 and 2005 were designed and prototyped by the author, using the existing wiring on these cars (backward compatibility) and replacing all electronics with open hardware. To accomplish this task, donated car electronics and wires that the author already has will be used. This will form the basis for commercializing automotive solutions for other car brands and models using open business logic (open hardware and open software). Includes LPG systems. Today, repairing hardware electronics is nearly impossible. Current practices force owners to replace rather than repair, which is costly and prompts owners to seek other, less reliable solutions using older components from other vehicles. Since this type of component is now heavily protected, whenever it is necessary to reverse engineer and modify the hardware electronics or firmware to enable and work in other vehicles, it is done outside of official car manufacturer authorized dealers Maintenance and repairs both carry additional risks. The main goal of this project is to study the advantages of using open solutions and compare them with traditional hardware electronic solutions. Especially regarding serviceability, maintenance and repairability, as well as security of personal ownership. While driving and while parked (anti-theft). First Milestone The main goal of the first milestone is to directly replace all proprietary hardware electronics with open hardware solutions that will be prototyped and specifically include: - This ECU is identical to the ECU sold by HalTech Austria and the famous Speeduino very similar. - ECU Diagnosis, Programming and Tuning Tablet Device - ETM Throttle Control - Air Bag Control Module - Electronic Stability Control - Dashboard LED Retro Lighting Module on Dashboard Oil Gauge Temperature Gauge Engine Tachometer Speedometer - LED Retro Lighting with LCD TFT Color display Engine tachometer Tachometer - Climate control module - Car media audio - Rear view mirrors - Door locks for each door and trunk LED retro lighting module (rear doors) - Control electronics for the headlights I will add A "cargo load" sensor to automatically adjust the headlight beam angle - backlight control electronics Second milestone In the second milestone, the factory air quality control unit will be replaced with a custom LCD screen, as well as the car audio in the center console, Specifically: - Adding an LCD screen to the center console running Android Auto through software customization Third Milestone In the third milestone, the factory dash unit will be replaced and replaced with a custom LCD screen, to enable some cool 3D graphics rendering, specifically: -Add an LCD screen to the dashboard to run some cool 3D graphics rendering -Compatible with the autonomous driving module Fourth Milestone In the fourth milestone, autonomous driving will be added Driving functions... - Obstacle detection and automatic breaking - Directly compatible with Comma.ai autonomous driving solution (open hardware and software
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 02:15:10
  • Urgent question!!!
  • What motor do you use?
  • Dip switch problem
  • RF chip design challenges
  • Helper2416-03——The first batch distributed, finally received the board!
  • Frequency calculation
