n9ulGy3cN
ESP8266 Activated Carbon Formaldehyde Removal Main Control Board
Activated carbon is used to adsorb formaldehyde, the outer shell is made by 3D printing, the PCB is made by JLCPCB, a centrifugal fan with high air pressure is used, the ESP8266 is connected to the network, and the Blinker can be remotely controlled and historical formaldehyde concentration can be viewed. The total cost is estimated at 90 yuan.
Please see the video on Bilibili: https://www.bilibili.com/video/BV1aapieMEst/ Overview:
                        https://www.bilibili.com/video/BV1hapieTE1L/ Hardware Introduction
                        : https://www.bilibili.com/video/BV1TE4zeEERW/ Software Introduction:
ESP8266 main controller,
CJSH22 formaldehyde sensor: https://detail.tmall.com/item.htm?_u=k3v6gk0837d&id=609585259969&skuId=4884397220013&spm=a1z09.2.0.0.57172e8dZZ7wus
The screen uses an IIC. 12864
motor for automotive blowers with fan: https://item.taobao.com/item.htm?_u=k3v6gk01cae&id=612166551562&spm=a1z09.2.0.0.57172e8dZZ7wus
3.3V to 5V PWM chip: https://item.taobao.com/item.htm?_u=k3v6gk06122&id=636691499892&spm=a1z09.2.0.0.57172e8dZZ7wus
Activated carbon filter housing for stainless steel window screens:
Approximately 2.5 kg of activated carbon is needed based on my designed dimensions.
Blinker for mobile app: https://www.diandeng.tech/doc
daima.ino
STL model.rar
SW model.rar
PDF_ESP8266 Activated Carbon Formaldehyde Removal Control Board.zip
Altium_ESP8266 Activated Carbon Formaldehyde Removal Control Board.zip
PADS_ESP8266 Activated Carbon Formaldehyde Removal Control Board.zip
BOM_ESP8266 Activated Carbon Formaldehyde Removal Main Control Board.xlsx
91709
SULILG 32-bit single-unit ESC
A single-unit ESC based on AM32 and HF32 (supports 8-bit switching)
The test video and attached
project parameters
are available. This solution separates the control board and power board, which can increase overcurrent. Users can freely choose to use an 8-bit or 32-bit control board.
AM and HF use the PB4 pin scheme, which is widely available online. BL_S uses the J_H_30 scheme, which is also widely available online.
This ESC supports 5V 3ABEC and can power peripherals.
This ESC uses 12 MOSFETs to increase heat dissipation and overcurrent. For NMOS transistor selection, you can use NTMFS5C430NLT1G or CSD18540Q5B, depending on your choice. As long as the voltage is >30V and the overcurrent is greater than about 80, it is acceptable.
In the 6-second voltage test, this ESC with a copper thickness of 0.5OZ can achieve around 20A and a temperature of 40-50 degrees Celsius. Under forced cooling, it can run at 50A for 30 seconds and reach a temperature of 80 degrees Celsius (increasing the copper thickness can provide better heat dissipation and overcurrent performance, or you can add a heatsink).
Rendering and
physical images are also available.
SULILG 32-bit Single-Unit ESC Test_1.mp4
SULILG 32-bit Single-Unit ESC Test_2.mp4
ESC data.rar
PDF_SULILG32-bit Single-Unit ESC.zip
Altium_SULILG32-bit single-unit ESC.zip
PADS_SULILG 32-bit single-unit ESC.zip
91710
Photoelectric obstacle avoidance device
Photoelectric obstacle avoidance module, used for obstacle avoidance in small vehicles.
The schematic diagram is as follows:
1. One set of LM393 operational amplifiers is used, and the other set is unused.
2. The adjustable resistor can adjust the distance between the amplifier and the obstacle.
3. The circuit diagram is as follows:
4. The physical diagram is as follows:
PDF_Optical Obstacle Avoidance Device.zip
Altium_Optical Obstacle Avoider.zip
PADS_Optical Obstacle Avoider.zip
BOM_6. Photoelectric Obstacle Avoidance Device.xlsx
91711
Microsoft Dinosaur
Free toy dinosaur, can be scratched to look like gold!
Free dinosaur charm, can be stamped with gold!
A super cute Microsoft dinosaur charm, perfect as a pendant or necklace!
PDF_Microsoft Little Dinosaur.zip
Altium_Microsoft Little Dinosaur.zip
PADS_Microsoft Little Dinosaur.zip
91712
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 16:36:21
