ZfWEwyxJ4
Topzhu A1/A1mini Series Fan Expansion Board
This is an expansion board for the extruder cooling fan interface of the A1/A1mini. It can separate the hot-end fan's wiring to power an additional fan.
You only need a 5V two-wire fan (for three-wire or four-wire fans, you need to remove the wires except VCC/GND).
The board comes in two versions: a speed-enhancing version that can double the speed of the hot-end fan. The hot-end fan of the Tuozhu A1 series only runs at 30% speed; using the speed-enhancing version will double the speed.
Regardless of whether it's speed-enhancing or not, the control strategy for the additional fan is "once the hot-end fan starts, it runs at full power." Therefore, when choosing a fan, please select one with good dynamic balance, minimal noise and vibration, and use foam adhesive to attach the fan to the extruder to reduce the impact of fan vibration on print quality.
I have designed a mounting bracket for a 4cm fan, which can be downloaded from Tuozhu MakerWorld.
Please note that this project is prohibited from commercial use. You can use it yourself, but you cannot sell it! If you really want to sell it, please contact me for commercial permission! Please do not use it for commercial purposes without permission! !
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 15:59:41
  • About interrupts
  • Introduction to EEWORLD University Credit Honor Roll
  • The module function address of driverlib.a solidified in ROM
  • C language learning suggestions
  • I always feel embarrassed and confused when I reach middle age.
  • Will the listbox redraw the window once a scroll bar appears?
