V0ePfM0Q
A clumsy, pseudo-Dell server power supply modification
Video Link:
Original author's video introduction
to the project
[Original author's open source link]
https://oshwhub.com/tomosawa/mynova-smartpower
No gold finger connector,
reserved temperature control function
, modified button position
, added current carrying capacity.
Software code
source code. The original author's project provides a git link.
Arduino development environment.
Code modifications needed:
1. Pins.
2. Simultaneous pressing of two buttons controls fan startup
. Initialization: pinMode(PIN_FAN, OUTPUT);
button
if (digitalRead(PIN_BUTTON_L) == LOW && digitalRead(PIN_BUTTON_R) == LOW) {
// Switch the level of the FAN pin
digitalWrite(PIN_FAN, !digitalRead(PIN_FAN));
3. Board temperature control function
not written
The partition file needs to be imported for correct programming.
Place the partition file in C:\Users\Username\AppData\Local\Arduino15\package\sesp32\hardware\esp32\2.0.9 In the `allspartitions` directory,
open the `boards.txt` file located in `C:\Users\Username\AppData\Local\ Arduino15\package\sesp32\hardware
\esp322.0.9`. Find the `esp32s3dev`
section and locate the "Add Partition Configuration File" section.
Add the following code below it:
`esp32.menu.PartitionScheme.mynova_16mb=MYNOVA 16MB`
`esp32.menu.PartitionScheme.mynova_16mb.build.partitions=MYNOVA_16MB`
`esp32.menu.PartitionScheme.mynova_16mb.upload.maximum_size=3145728`
. For versions below 2.0, restarting Arduino will take effect . For versions
2.0 and above, delete the `leveldb` folder located in `C:\Users\Username\AppData\Roaming\arduino-ide\Local Storage`. Then open Arduino. (This operation will clear the cache and the interface will revert to English. Simply switch back to Chinese.) This is a beginner's guide
to flashing configuration
tips
; please forgive any errors and feel free to point them out.
The 10kb B-value 3450 thermistor
slot is too small. These two areas need to be slightly sanded down with a screwdriver or small file (not much).
PDF_Clumsy Little Fake Dell Server Power Supply Mod.zip
Altium_Clumsy Little Fake Dell Server Power Supply Mod.zip
PADS_Clumsy Little Fake Dell Server Power Supply Mod.zip
BOM_Clumsy Little Fake Dell Server Power Supply Modified Version.xlsx
92339
Automotive taillight control circuit design
This course design is mainly aimed at the requirements of analog electronics and digital electronics courses. It aims to cultivate students' comprehensive ability to design, calculate, simulate, and debug application circuits based on consulting materials, and at the same time, to cultivate students' ability to independently solve practical problems using the theories they have learned.
(Assume there are 3 indicator lights on each side of the rear of the car. All lights are off when the car is running normally. When turning right, the 3 lights on the right side will light up in a right-circuit sequence. When turning left, the 3 lights on the left side will light up in a
left-circuit sequence. When braking, all lights will flash simultaneously.) (1) Design, simulation and debugging of
the right-circuit circuit of the headlights; (2) Design, simulation and debugging of the left-circuit circuit of the headlights;
(3) Design, simulation and debugging of the delay circuit. When the headlights are cyclically lit and flashing, the lighting and extinguishing time is 2 seconds, with an accuracy greater than 10%;
(4) Design, simulation and debugging of the state switching circuit; (
5) Scheme design and demonstration;
(6) Use relevant software to design and simulate the circuit diagram, and analyze and summarize the simulation results.
BOM_Board1_Schematic1_2024-01-06.xlsx
Design1(upgrade).ms14
PDF_Automotive Taillight Control Circuit Design.zip
Altium_Automotive Taillight Control Circuit Design.zip
PADS_Automotive Taillight Control Circuit Design.zip
BOM_Automotive Taillight Control Circuit Design.xlsx
92340
ESP32 Mini TV
This device implements a mini-TV function based on the ESP32-pico-d4, while adhering to the principle of low cost in component selection, allowing connection to a display screen via the exposed screen interface.
This device, based on the ESP32-pico-d4, functions as a small TV, serving as a desktop terminal and decorative item, displaying information such as time and weather. Additionally, due to the gyroscope on the board, it can also play games like 2048. Due to size restrictions, the full image cannot be displayed here; a full image is provided instead.
PDF_ESP32 Mini TV.zip
Altium_ESP32 Mini TV.zip
PADS_ESP32 Mini TV.zip
BOM_ESP32 Small TV.xlsx
92341
ESP32 Multifunctional Temperature and Humidity Clock
1. Project Description:
a. Create a desktop clock that displays time and temperature.
b. Include IoT buttons to control computer power-on and indoor lighting.
c. Upload temperature and humidity data to Home Assistant to control home temperature (operate air conditioner and humidifier).
Schematic Diagram Explanation:
a. Main control chip uses ESP32-C3, employing a ceramic antenna.
b. Type-C power supply and data programming.
c. 6211 LDO 5V to 3.3V power supply.
d. Real-time clock uses DS1302.
e. The temperature and humidity sensor uses a DHT11
display, with two
options: a 3.2-inch OLED and
a digital-to-analog tube (DAC). The
latter is currently being tested. The battery uses a single 18650 cell, a TP5400 charge/discharge regulator chip, and an IP3005A battery protection chip.
The structure consists of
four boards: a core board, a battery board, a display board, and a button board. The core board, battery board, and display board are connected by 11mm copper pillars, and the button board is connected by bent female connectors. The connection is quite secure, with no looseness. The
following image shows the actual product, and the effect is acceptable. It looks a bit like a C4 chip, haha.
PDF_ESP32 Multifunctional Temperature and Humidity Clock.zip
Altium_ESP32 Multifunctional Temperature and Humidity Clock.zip
PADS_ESP32 Multifunctional Temperature and Humidity Clock.zip
BOM_ESP32 Multifunctional Temperature and Humidity Clock.xlsx
92343
Learning extension based on SkyStar STM32F407VET6
Based on the LCSC Skystar STM32F407VET6 learning expansion board
This expansion board is based on the Skystar STM32F407VET6 and consists of an OLED display, a digital tube, an NRF24L01 and TB6612FNG motor driver chip, buttons, etc. It is convenient for beginners to learn about IIC, SPI, timers, external interrupts, and other related knowledge. It also includes motor drivers and supports the use of I2C motors and ordinary motors. All pins on the development board are brought out, providing convenience for subsequent learning of other peripherals.
STM32F407VET6 expansion board pinout.txt
STM32F407VET6 Expansion Board Applications.zip
PDF_Extended Learning Version Based on SkyStar STM32F407VET6.zip
Altium_Learning Extension Version Based on SkyStar STM32F407VET6.zip
PADS_Learning Extension Edition Based on SkyStar STM32F407VET6.zip
BOM_Based on Skystar STM32F407VET6 Learning Extension.xlsx
92345
ESP32-based smartwatch verification board
The smartwatch verification board, designed based on the chappie2 open-source project,
is equipped with a microphone, barometer, posture sensor, RTC clock,
and USB support for switching between ESP-USB and USB-to-serial ports.
The project has been verified. The overall design is based on https://oshwhub.com/eedadada/chappie2 . The USB switching circuit has been modified to support switching the USB-C function via a switch. The onboard USB to serial port facilitates debugging.
This is my first time designing a board. Compared to the reference project, it has reduced the difficulty to a certain extent. After this board is successfully verified, we will consider the subsequent improvement plan . [ ] Change the power management to AXP2101 [ ] Add a vibration motor [ ] Modify the board shape and circuit to make it more suitable for watches [ ] Add a MAX30102 heart rate sensor. The software is based on ESP-IDF. Developed using v5.3, code details can be found at https://gitee.com/liu-lejian/kotone-watch. The sensor I2C driver is based on the new i2c_master.h header file of ESP-IDF and does not support older versions of the ESP-IDF i2c.h header file. The USB switching circuit can switch between ESP-USB and UART-USB, but hot-switching is not supported; the Type-C port needs to be unplugged and plugged back in for the switch to take effect. It uses many surface-mount components; replication is not recommended without a heating platform/hot air gun.
PDF_ESP32-based Smartwatch Verification Board.zip
Altium_ESP32-based Smartwatch Verification Board.zip
PADS_ESP32-based Smartwatch Verification Board.zip
BOM_ESP32-based Smartwatch Verification Board.xlsx
92346
ECGEV
Heart rate card, collects ECG waveforms, LED simulates an ECG to indicate heart rate, and supports sending ECG waveforms via Bluetooth.
AFE: AD8232
MCU: STM32WB55
ecgev.mp4
ECGW.zip
PDF_ECGEV.zip
Altium_ECGEV.zip
PADS_ECGEV.zip
BOM_ECGEV.xlsx
92348
Desktop mini weather clock
This project uses Espressif's ESP8266 as the main controller to drive a 1.54-inch TFT LCD screen, and employs capacitive touch buttons, WS2812 LEDs, and a buzzer to create a popular WiFi weather clock desktop decoration. In addition to the standard weather clock functionality, this project also includes a photo album feature.
This project uses Espressif's ESP8266 as the main controller; please ensure you purchase the correct model
to drive a 1.54-inch TFT LCD screen.
It utilizes capacitive touch buttons, WS2812 LED lights, and a buzzer to create a popular WiFi weather clock desktop decoration.
In addition to the standard weather clock functionality, this project adds a photo album feature, allowing for one-click upload and deletion via a mini-program or webpage, further enhancing its practicality. Capacitive touch buttons are also added for switching interfaces, increasing ease of use and interactivity.
The addition of WS2812 LED lights adds a cool effect to the small TV, offering various ambient lighting effects: fixed color; fixed color breathing light; and fixed brightness gradient color. A buzzer is added to function as an alarm clock, a long-awaited and practical feature. It supports setting up to three alarms, each with options for: single alarm, weekday, and daily alarms, sufficient for daily use.
The CH340 chip is used for programming.
The following is the bill of materials.
3D Shell.rar
Gerber_Open Source ESP8266 Weather Clock WiFi Mini TV GIF Animation Custom Upload_2024-05-15.zip
PDF_Desktop Mini Weather Clock.zip
Altium Desktop Mini Weather Clock.zip
PADS_Desktop Mini Weather Clock.zip
BOM_Desktop Mini Weather Clock.xlsx
92349
ESP32 WiFi temperature and humidity ornament
A desktop ornament for temperature and humidity control that connects to WiFi using ESP32-C6.
The main control chip is ESP32-C6-MINI, used to connect to WiFi and obtain current weather and temperature changes. Before use, you need to pre-set the WiFi name (preferably without spaces, otherwise it won't connect), WiFi password, and location to obtain the current temperature and time.
The built-in AHT20 sensor detects the ambient temperature and humidity, providing a more accurate representation of perceived temperature and humidity.
The display uses an e-ink screen with a simple interface and low power consumption. Icons are sourced from the internet; the image is shown below.
The charging section uses a TP4056 charging/discharging chip to meet charging needs; the battery can be selected according to your requirements.
The casing can be designed to match the size of the e-ink screen price tag. The overall effect is shown below:
PDF_ESP32 WiFi Temperature and Humidity Ornament.zip
Altium_ESP32 WiFi Temperature and Humidity Ornament.zip
PADS_ESP32 WiFi Temperature and Humidity Ornament.zip
BOM_ESP32 WiFi Temperature and Humidity Ornament.xlsx
92350
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-25 23:01:54
  • Commonly used computer command sets
  • CCS4.2 certificate and certification documents
  • Please give me some advice, stm32f107host problem
  • LM3S9B96 + wireless wifi zigbee bluetooth... the end...
  • About CeCreateProcess problem! Urgent!
  • How can I squeeze on the train home~~
