YHX1irxC
8.14-inch SES4-color price tag driver board
This is an 8.14-inch 4-color SES electronic shelf label e-ink screen driver board with dual ICs (IC suspected to be JD79686AB) and dual ribbon cables. Theoretically, it can also be used with 6-color boards of the same size. It comes with an adapter FPC, with pins identical to those in the Waveshare 7.3G, where the CS pin of the IC is located on pin 34.
PDF_8.14-inch SES4-color price tag driver board.zip
Altium 8.14-inch SES4-color price tag driver board.zip
PADS 8.14-inch SES4-color price tag driver board.zip
BOM_8.14-inch SES4 color price tag driver board.xlsx
93239
35 Closed-loop stepper motor driver board && vise control board
This project used CNC sheet metal and some mechanical parts to fabricate an electric welding vise. The CNC components were prototyped at JLCPCB's 1 Yuan CNC prototyping event. The drive section uses a closed-loop stepper drive, and the motor drive board is suitable for a 35 stepper motor.
Project Introduction:
This project utilizes CNC sheet metal and some mechanical parts to construct an electric welding vise. The CNC components were prototyped at JLCPCB's 1 Yuan CNC prototyping event. The drive system uses a closed-loop stepper drive, and the motor drive board is compatible with a 35 stepper motor. It can be used in other projects. The plan includes the following functions: closed- loop button setting for
vise position, automatic adjustment of clamping current (to be implemented), long-term automatic sleep mode (to be implemented), external control input (to be implemented), and manual version video demonstration: bilibili. Software open-source address: github. Software part references "Contradictory Aggregator". Hardware open-source address: oshwhub. Hardware part references "HyperStepper" . Bill of Materials : 1. Components required for the circuit board (BOM) are given . 2. Structural part: Item No. Name Quantity Link 1 CNC aluminum plate 3 JLCPCB CNC prototyping 2 2020 aluminum profile 120mm tapped at both ends M6 2 Reference Connection 3 8mm optical shaft 130mm (no burrs at both ends) 2 Reference Connection 4 Double-edged flange linear bearing 8x15x24 2 Reference Connection 5 T8 lead screw 143mm pitch 2 lead 8 1 Reference Connection 6 Miniature flange bearing F688Z (8*18*5) Manual: 2 / Electric: 1 Reference Connection 7 Backlash-free nut T8 lead 8 1 Reference Connection 8 T8 lead screw lead screw nut pitch 2 lead 8 1 (Generally included with the purchase of a lead screw) Reference connection 9 Coupling 5*8 Manual: 0 / Electric: 1 Reference connection 10 M6x14 Screw 4 11 M3*12 *4 (head diameter) Small head screw 10 12 35 Stepper motor Manual: 0 / Electric: 1
model.zip
Demo video.mp4
model modified version.zip
PDF_35 Closed-Loop Stepper Motor Driver Board & Vise Control Board.zip
Altium_35 Closed-Loop Stepper Motor Driver Board & Vise Control Board.zip
PADS_35 Closed-Loop Stepper Motor Driver Board & Vise Control Board.zip
BOM_35 Closed-Loop Stepper Motor Driver Board & Vise Control Board.xlsx
93240
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 18:21:56
