Demo video: https://www.bilibili.com/video/BV1PXedeyEzk/?pop_share=1&vd_source=90cd0bf85dee77e1771d16ef64a1b58a
Basic Functions: 1. Power input supports TYPE-C, TYPE-A, XH2.54-4P, and DC5V-12V input. The DC input interface can detect the voltage (charge) of connected 2S and 3S lithium batteries (connection cap switching). 2. System voltage supports 5V and 3.3V, with a main switch, trip switch, and self-resetting fuse. Supports one-key restart, USB-DC power supply switching, and one-key on/off of backup power (button battery or external battery). MCU power supply supports 5V-3.3V switching (connection cap switching). VREF+ supports 2.5V reference voltage - VCC power supply voltage switching (connection cap switching). 3. Full-featured MCU expansion interface. 4. It features five MQ series gas sensor peripheral interfaces, one AHT20+BMP280 fusion module interface, one six-axis attitude sensor interface (MPU6050), one atmospheric pressure sensor interface (BMP280), one 2.4G wireless communication module interface (NRF24L01+), one WIFI module interface (ESP8266-01S), one Bluetooth module interface (HC-06), one three-axis magnetic field sensor module interface (electronic compass), one temperature and humidity sensor module interface (DHT11), and one one-wire... Features include a temperature sensor interface (DS18B20), an ultrasonic module interface (HC-SR04), two LoRa wireless communication module interfaces (HC-14), a multi-function display interface (supporting 8P-TFT, IIC mode OLED, and SPI mode OLED), four DC motor drivers (PWM+NMOS combination), five buttons (supporting hardware debouncing, no software debouncing required), an active buzzer (low-level drive), a set of red and blue LEDs (two 0805 high-brightness LEDs), and a set of LED sequential lights (four 0603 low-brightness LEDs).
V1.1: Fixed the USB-Link interface orientation issue and added a direct-plug HX-4P interface, allowing for either side-plug or direct-plug selection.
See the actual product below:
PDF_Microcontroller Creative Design Competition - Wireless Environmental Monitoring and Development Board.zip
Altium Microcontroller Creative Design Competition - Wireless Environmental Monitoring and Development Board.zip
PADS_Microcontroller Creative Design Competition - Wireless Environmental Monitoring and Development Board.zip
BOM_Microcontroller Creative Design Competition - Wireless Environmental Monitoring and Development Board.xlsx
93542
STC8051U Development Board
A development board based on the STC8051U. It uses STC's hardware USB download (USB-HID). HID devices are driverless, so downloading can be done directly without installing drivers.
I. Development Board Function Overview
1. Direct USB download and simulation
2. Full-color REG circuit
3. Passive buzzer
4. Two-digit LED display 5.
DS118B20 temperature sensor, DHT11 temperature and humidity sensor
6. Infrared receiver
7. 485 communication 8.
555 counter
9. ADC voltage measurement
10. Photoresistor voltage measurement
11. RTC clock
12. LED circuit
13. Button circuit
14. OLED screen interface compatible with SPI-7pin, SPI-8pin, and IIC-4pin
15. Three-pin universal sensor interface
16. Four-pin sensor interface for PCF8563/BMP180/MPU6050, etc.
17. Power interface (power voltage header leads)
18. All pins of the STC8051U chip are brought out.
II. Schematic Introduction:
The main control chip
is based on the STC8051U. The datasheet details that
the RTC clock
must use a 32.768kHz clock. This is because dividing the 32.768kHz clock frequency 15 times yields a frequency of 1Hz.
One second is exactly 1Hz, which facilitates the generation of a 1-second clock frequency.
The button circuit
does not require pull-up resistors and capacitors, which is very convenient. The P32 port button can be used for downloading via
TYPE-C. The power supply circuit
is based on a ME6231 high-precision low-dropout linear regulator. The CE pin of the regulator chip is connected to the switch,
used in conjunction with the P32 button for power-on/off operations during downloading, thus enabling the use of the USB-HID communication protocol.
The external header is used to connect tools such as the STC-USB Link1D. I used a dual-purpose adapter (USB to dual serial port), which is very convenient.
The lower four digits of port P0 are for a digital tube display, and the higher four digits are for LED
digital tubes . The circuit
uses a CD4511 to drive the digital tubes; the CD4511 is a BCD code encoder. The enable pins are already connected; only the microcontroller pins need to be controlled
to output the corresponding values. For
the LEDs,
an SS8550 PNP transistor is used to enable the LED
REG light .
Three pins of the microcontroller control different colored lights, mixing red, green, and blue to emit different colors. For
single-bus temperature measurement,
both are common sensors: the DS18B20 is a temperature sensor, and the DHT11 is a temperature and humidity sensor.
The passive buzzer circuit
requires a specific frequency electrical signal to drive it; different frequencies produce different sounds.
The P52 pin can be set to PWM mode, making driving convenient.
Pin headers and jumpers are used to control the buzzer's on/off state.
The infrared receiving circuit
uses infrared light, an electromagnetic wave with a frequency between microwaves and visible light, and a wavelength between 1 mm and 760 nanometers (nm). It is invisible light with a frequency lower than red light. The receiver uses an infrared diode, utilizing the photoelectric effect, filtering, and power amplification to form a digital signal capable of carrying a signal.
A 555 timer
adjustable resistor is used to adjust the frequency of the 555 timer. Pin P34 can be configured for external input counting .
485 communication
allows for external communication using a 485 chip. P50 and P51 are the microcontroller's serial ports .
The ADC circuit
uses a photoresistor and adjustable resistor to divide the voltage, which is then read by the microcontroller's ADC.
A copper plate in the lower right corner of the PCB is used for analog ground.
External device interfaces
can be used to connect various sensors. The microcontroller's MOSI/MISO
interface
can be switched; using P32/P33 allows for both IIC and SPI interfaces. While mine is compatible with various screen connections, IIC communication requires writing the timing code yourself.
However, there are many online resources available, and development is not difficult.
III. Demonstration of Some Physical Functions:
Downloading
can be completed using only a Type-C cable, without the need for driver installation, which is very convenient.
Download Process:
1. Open the STCAI-ISP software.
2. Select the corresponding chip model
. 3. Select the HEX file to download.
4. Set the IRC frequency.
5. Press and hold the P32 pin (do not release), then press the enable button on the voltage regulator chip to power off, and then release the enable button to power on.
At this point, you can see that (HID1) STC-USB Writer 6 has been detected.
Finally, click download. For
LINK tool download,
I'm using a USB to dual serial port downloader.
After connecting the tool to the pin header on the development board, you can click download in STCAI-ISP, which is very convenient.
Environment setup:
1. You need to add the STC header file first. Use the STCAI-ISP software to add
the file. The add path is the KEIL installation path.
2. Create a KEIL project. Select STC to find this chip (you can choose 8-bit or 32-bit).
3. Select the storage mode.
4. Finally, generate a HEX file for burning
STCAI-ISP
. STCAI-ISP is a very useful tool with many other functions besides downloading,
such as serial port assistant, baud rate calculation, timer calculation, software delay calculation, etc.
Here, I use the I/O port configuration tool for pin configuration. The configured code is directly placed in the main function for initialization,
and it's ready to use, which is very convenient.
LED & Digital Tube
REG
OLED refresh rate is very fast.
113.mp4
111.mp4
PDF_STC8051U development board.zip
Altium_STC8051U development board.zip
PADS_STC8051U development board.zip
BOM_STC8051U Development Board.xlsx
93543
STC32_骦
Core board based on STC32G12K128 microcontroller
All components on the Linn development board
are surface-mount, resulting in fewer components that can be soldered using a hot plate or hot air gun.
All pins are brought out for ease of use, and numerous 5V and 3.3V outputs have been added.
The tantalum capacitor next to the AMS1117 requires careful attention to polarity; otherwise, it might make a loud noise.
The ISP download is still under verification and modification .
PDF_STC32_骦.zip
Altium_STC32_骦.zip
PADS_STC32_骦.zip
BOM_STC32_骦.xlsx
93545
Dell Server 750W Power Adapter
This direct-soldering adapter board for DELL server power supplies eliminates the need for expensive connectors, providing unified power to devices such as software routers, optical modems, and switches. It includes a reserved XH2.54 PMBus interface for accessing power supply voltage, current, and power information.
It's time to equip your optical modem, soft router, switch, and other devices with a cost-effective, high-performance platinum power supply
. One power supply solves the power needs of all your 12V devices.
No expensive connectors are needed; this direct-soldering DELL server power supply adapter board provides unified power to soft routers, optical modems, switches, and other devices. It includes an XH2.54 PMBus interface for reading power supply voltage, current, and power information.
The finished product is shown in the image below. There are only six surface-mount components in total; you can leave them all unsoldered if you don't need indicator lights. Only the switch needs to be soldered (or you can connect them all together with a lump of solder, saving you the trouble of soldering the switch itself).
PDF_Dell Server 750W Power Adapter Board.zip
Altium_Dell Server 750W Power Adapter Board.zip
PADS_Dell Server 750W Power Adapter Board.zip
BOM_Dell Server 750W Power Adapter Board.xlsx
93548
STC Bluetooth serial port LED board
STC Bluetooth serial port LED lighting, with 64 onboard LEDs and a Dobtm03 LED from Baidu Cloud Mall.
It's been verified that the Bluetooth power control was modified once; a wire was missing, but it's been fixed (on the MOSFET side). The modified one hasn't been verified yet, but it should be fine. The specific function hasn't been decided yet; it could be used for pendants, toys, etc.
My 662k is still at school for the holidays; I'm using an 1117 jumper cable instead. That should work fine.
VID_20240724_185224.mp4
VID_20240721_000220.mp4
doBT-01 series Bluetooth documentation.zip
lanyachuankou_v7.4.7_downcc.com.apk
stc8h8k64_serial port LED.zip
PDF_stc Bluetooth serial port LED board.zip
Altium_stc Bluetooth serial port LED board.zip
PADS_stc Bluetooth serial port LED board.zip
BOM_stc Bluetooth serial port LED board.xlsx
93550
TPS5430 Negative Voltage Module -12V Low Ripple
A negative voltage module using TPS5430 outputs -12V, and low ripple output is achieved using a secondary LC filter.
PDF_TPS5430 Negative Voltage Module -12V Low Ripple.zip
Altium_TPS5430 Negative Voltage Module -12V Low Ripple.zip
PADS_TPS5430 Negative Voltage Module -12V Low Ripple.zip
BOM_TPS5430 Negative Voltage Module -12V Low Ripple.xlsx
93551
A small mobile phone based on the Taishan School
This project is a learning project submitted to the LCSC Taishan Training Camp.
The knowledge points involved include: circuit design, PCB design, PCB soldering, Linux device trees and drivers, structural design, and 3D printing.
I. Project Description
This project is a small mobile phone project based on the LCSC development board "Taishanpai". The learning content includes: Linux compilation environment setup, SDK compilation, common Linux commands, device tree, screen selection and debugging, screen touch driver, etc.
The main tasks in this project include designing and soldering a 3.1-inch MIPI screen adapter board, designing and 3D printing the small mobile phone casing. The program currently uses the "default landscape" firmware. After assembly, I will try writing my own program. Based on
my design of the "3.1 MIPI adapter board" in the training camp, I added "12V PD power supply" and "UART", both of which use Type-C connectors. This increases the distance between the "Taishanpai" and the "adapter board", so the length of the "surface nut post" and "pogo pin" is insufficient and needs to be reselected. At the same time, the casing needs to be redesigned to increase the "thickness" of the phone, and two new "Type-C" interfaces need to be added to the casing.
Because the length of the pogo pin has a range (before and after spring compression), the length of the surface nut post is determined first, and then the pogo pin is selected. After testing in SW, it was found that the distance between "Taishanpai" and "adapter board" changed from 3mm to 6mm, which is enough to fit the typec socket. Therefore, a 6mm high surface mount nut post was selected on the board, and a 6.5mm high pogo pin was selected on the board (6.5 before compression, 4.5 at the compression limit).
During the learning process in the training camp, most of the time I watched the live replays and watched each video carefully. Because the original tutorials jump back and forth between multiple links, it is not easy for a beginner to get an overall idea. Therefore, based on the original tutorials, I wrote CSDN according to my own understanding, sorted out the ideas, and "added" the problems I encountered in the learning process. There are some articles with a high degree of completion, the links are as follows:
(1) Environment setup and SDK compilation
(2) Common Linux commands
(3) Linux device tree
(4) Screen selection and debugging
(5) Comprehensive project
Note: The above articles are for my own reference in the future and are more applicable to myself.
The official tutorial for Taishanpai is available here. Part
II: Schematic Design
. This schematic design refers only to the 3.1 MIPI adapter board. Most of the circuitry follows the official tutorial, so the principles will not be explained further; only the general approach will be outlined.
The wiring sequence of the Taishanpai 3.1 MIPI interface is inconsistent with that of a 3.1-inch screen, so an adapter board is needed to match the wiring sequences.
Taishanpai itself has a backlight circuit, which is led out through the 3.1 MIPI interface, with a maximum output of 110mA. However, the maximum backlight current that a 3.1-inch MIPI screen can withstand is 25mA. Directly connecting the Taishanpai's backlight circuit to the screen could cause it to overheat or even burn out. Therefore, the 3.1 MIPI adapter board is designed with two backlight paths: one provided by the Taishanpai MIPI connector, and the other by the onboard backlight circuit. These are selected using a 0Ω resistor.
The 3V3 of the Taishanpai MIPI connector provides power to the onboard backlight circuit, and the PWM signal controls the output voltage of the onboard backlight circuit. TP's I2C is converted to PWM via an I2C-to-PWM chip. Therefore, TP's I2C terminal controls both the touchscreen and the backlight.
The newly added PD power supply and UART circuit are as follows:
CH224K uses a single resistor configuration; CFG1 is grounded via a 24K resistor, which will induce a 12V voltage.
III. PCB Design:
See notes for the comprehensive project.
IV. Purchase Items List:
Material
Model
Reference Link
Taishanpai
2+16
https://lckfb.com/project/detail/lctspi-2g-16g?param=baseInfo
Recommended version: 2+16.
MIPI adapter board
is not
available in this project
; you can directly prototype it and then purchase components according to the BOM, soldering the adapter board. RTC connector without Pogo pins and surface mount nuts are sold separately.
Pogo pins with
a 6.5mm surface mount height are available here
: https://item.taobao.com/item.htm?u=f352jcuff2f2&id=750082995689&spm=a1z09.2.0.0.47fc2e8dDghyEo
6.5mm surface mount
nuts are available here: https://detail.tmall.com/item.htm?u=f352jcuf5bf0&id=675714153951&spm=a1z09.2.0.0.47fc2e8dDghyEo&skuId=5033314679469 31-pin MIPI FPC cable with a 0.3mm surface mount height is also available here
: https://detail.tmall.com/item.htm?u=f352jcuf5bf0&id=675714153951&spm=a1z09.2.0.0.47fc2e8dDghyEo&skuId=5033314679469 Type A, 50mm long, same direction: https://item.taobao.com/item.htm?u=f352jcuf07f9&id=618662306027&spm=a1z09.2.0.0.5d7f2e8dnF3uzf One TP-Link FPC cable, 26 pins, 0.5mm, Type A, 50mm long, same direction: https://item.taobao.com/item.htm?u=f352jcuf69d2&id=555563074622&spm=a1z09.2.0.0.5d7f2e8dnF3uzf One cable , M2x12 screws. https://detail.tmall.com/item.htm?id=616455063246&spm=a1z09.2.0.0.5d7f2e8dnF3uzf&u=f352jcuf57ce No need to buy nuts, at least 3 are required. V. Acknowledgements: Thanks to Engineer Wu, the development team, and the LCSC development board team.
6d115d85579ffd75efaae2673a18bab5.mp4
PDF_A Small Mobile Phone Based on the Taishan School.zip
Altium - A small mobile phone based on the Taishan School.zip
PADS_A small mobile phone based on the Taishan School.zip
BOM_Based on Taishanpa's Small Mobile Phone.xlsx
93552
STC32G12K128 microcontroller development board
STC32G12K128
Minimum system board based on STC32G12K128, USB download, no serial port chip required.
PDF_stc32g12k128 microcontroller development board.zip
Altium_stc32g12k128 microcontroller development board.zip
PADS_stc32g12k128 microcontroller development board.zip
BOM_stc32g12k128 microcontroller development board.xlsx
93554
electronic
