POcReCmgh
STC8H8K64U Robot Arm Cart Bluetooth Control Board
This STC8H8K64U-based quadruped robot arm/360-degree servo motor Bluetooth control board
can be used as a control board for servo-based quadruped robots, robotic arms, and cars. It allows for convenient modification and monitoring of various parameters via Bluetooth, and also enables debugging of all PWM-based modules. It features 8 adjustable duty cycle and period PWM channels, and further functionality can be achieved through code modification.
Advantages include:
1. Small size, occupying less than two bottle caps (51mm x 46mm);
2. An added OLED display module for convenient debugging and increased expandability,
displaying current serial port reception information (UART, MS) ,
duty cycle of the 8 PWM channels,
Bluetooth connection status,
and quick preview of currently modified PWM values
; 3. Convenient Bluetooth module control, using a mobile phone as a remote control.
This app is written using App Inventor's visual programming interface and only supports basic functions,
controlling 8 PWM channels via Bluetooth modules (HC-05, JDY-31, etc.)
; 4. Utilizing STC's USB-to-serial conversion function, it allows direct USB program download, supports uninterrupted downloading, and facilitates code debugging.
A physical demonstration is available (see attached video).
appinventor core board host computer project.aia
Launch animation.mp4
Robotic arm hands-on control.mp4
STC8H code.zip
PDF_STC8H8K64U Robotic Arm/Car Bluetooth Control Board.zip
Altium_STC8H8K64U Robot Arm/Car Bluetooth Control Board.zip
PADS_STC8H8K64U Robot Arm/Car Bluetooth Control Board.zip
BOM_STC8H8K64U Robot Arm/Car Bluetooth Control Board.xlsx
93882
STC8 Minimum System Development Board
All I/O ports have been brought out.
I2C, SPI, USART2, USART3, and USART4 I/O ports are also separately brought out for easy module use.
To program, simply pull the BOOT button low and power on again.
LED2 blinks by default upon power-on; the blinking can be controlled via the keyLeft button.
LED3 is off by default; its on/off state can be controlled via the keyRight button.
The test program is attached and can be downloaded and programmed for testing and verification.
Demo video address:
https://www.bilibili.com/video/BV1G3hoeDELZ
stc8.hex
PDF_stc8 Minimal System Development Board.zip
Altium_stc8 Minimal System Development Board.zip
PADS_stc8 Minimal System Development Board.zip
BOM_stc8 Minimal System Development Board.xlsx
93884
Miyoo Horizontal Version 2.8 with Joystick
Miyoo 2.8 horizontal scrolling game with joystick, after flashing CFW firmware, can smoothly play GBA, PS1 and some arcade games.
First of all, thank you to the original open-source project released by "Don't be disappointed" (QQ group number: 514419296)! https://oshwhub.com/sunnygold/2.4cun-Miyooheng-ban-zhang-ji
This modified circuit was based on some adjustments made to the components I had on hand, and an analog joystick circuit was added (not a firmware modification, but rather the implementation using two comparators connected to the original buttons). The firmware can be flashed with Situ's open-source firmware or miyoocfw (https://github.com/TriForceX/MiyooCFW).
(The casing has only been tested with FDM PETG 0.15mm precision printing; photopolymerization has not been tested, so it's unclear if it will work.)
Shell STL.zip
Main component purchase address.xlsx
PDF_Miyoo Horizontal Version 2.8 with Joystick.zip
Altium_Miyoo Horizontal Scrolling 2.8 with Joystick.zip
PADS_Miyoo Horizontal Scrolling 2.8 with Joystick.zip
BOM_Miyoo Horizontal Scrolling 2.8 with Joystick.xlsx
93886
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 16:43:55
