U5ROwNIr
Capacitive soil moisture detection
PDF_Capacitive Soil Moisture Detector.zip
Altium_Capacitive Soil Moisture Detector.zip
PADS_Capacitive Soil Moisture Detector.zip
BOM_Capacitive Soil Moisture Detection.xlsx
94430
STM32-based baby crib design
This baby crib design, based on STM32, can detect baby's cries, wake-up, and body temperature, and can also rock the crib and play music.
The main control chip is an STM32F103C8T6. It is equipped with modules for a sound sensor, infrared sensor, temperature sensor, stepper motor, and voice broadcast. The sound sensor detects the baby's cries, the infrared sensor detects if the baby is sitting up, the temperature sensor detects the baby's temperature, the stepper motor simulates a rocking motion, and the voice broadcast module plays music to help the baby fall asleep.
STM32-based baby crib design program (partial April 22nd).zip
eb0c756c63ede9cabce2f0908baaf4ea.mp4
1d7bab780e4cf01bf36bfe2c8d96bdb6.mp4
PDF_STM32-based baby crib design.zip
Altium-based STM32-based baby crib design.zip
PADS_STM32-based Baby Crib Design.zip
BOM_STM32-based baby crib design.xlsx
94431
Intelligent aquarium water filtration and oxygenation system
This system is based on an STM32 main controller, CH224x chip, 0.6-inch OLED display, NTC temperature sensor, 12V water pump, and 3D printed casing. It's designed to be a smart and controllable water filtration system for small fish tanks, complete with an air pump control and supports serial port or app control.
1. The main controller is based on an STM32G030F6 for ambient temperature detection and PWM power adjustment of the water pump (with timer or day/night mode to reduce noise).
2. A CH224X chip is used to induce voltage from the PD power supply to power the microcontroller and water pump.
3. A 0.6-inch OLED screen allows for intuitive viewing of power supply voltage parameters and PWM output duty cycle parameters.
4. Two NTC temperature sensors detect and display the ambient temperature in real time for easy viewing. It can also be placed in a fish tank to monitor water temperature and control heating or cooling equipment.
STM32G030F_CH224KXX.rar
C970725 USB Chip CH224K Datasheet WJ1073926.PDF
PDF_Intelligent Fish Tank Water Filtration and Oxygenation System.zip
Altium Intelligent Aquarium Water Filtration and Oxygenation System.zip
PADS_Intelligent Aquarium Water Filtration and Oxygenation System.zip
BOM_Intelligent Aquarium Water Filtration and Oxygenation System.xlsx
94433
XREAL AR glasses adapter with modified power board for simultaneous use and charging.
When using the XREAL AR glasses, I found that the adapter has a built-in battery and cannot be used while charging. This gave me the idea of ​​creating an adapter that allows for simultaneous use and charging.
The adapter uses an LMR14030 to provide a wide 4-40V input voltage, initially stepping down to 5V; then a TP4510 steps down to 4.2V, providing battery protection.
The lower half of the adapter houses a large battery, providing ample space on the power board, even allowing room for a small battery
! [Image 1]
[Image 2] This does not affect the adapter's battery indicator lights (the original battery is a high-voltage lithium battery; the power board uses a TP5410 with a charging cutoff voltage of 4.25V, so even when fully charged, only two indicator lights will illuminate)
. [Image 3] The side panel has an opening, using an XT30 as the power input interface
. [Image 4] Overall connection effect; using a 12V input, the battery current is 1A.
[Image 1]
[Image 2] The glasses display is normal, with no flickering
. [Image 3] [Image 4]
PDF_XREAL AR glasses adapter modified power board for simultaneous use and charging.zip
Altium_XREAL AR glasses adapter with modified power board for simultaneous use and charging.zip
PADS_XREAL AR glasses adapter with modified power board for simultaneous use and charging.zip
BOM_XREAL AR glasses adapter modified power board for simultaneous use and charging.xlsx
94434
Fanyi Education - Coin Detection Circuit
Fanyi Education Coin Detection Circuit
2022 Electronic Design Contest
Program Link: lovefoolnotme/Open Source Project - Gitee.com
Blog Link: Coin Detection Circuit Design - CSDN Blog
FanYi Education Tutorial Link: Session 1: Coin Detection Device Principle Analysis, Circuit Design and Component Selection - Bilibili
Coin Detection.rar
VID_20240531_180233.mp4
PDF_Fanyi Education - Coin Detection Circuit.zip
Altium_Fanyi Education - Coin Detection Circuit.zip
PADS_Fanyi Education - Coin Detection Circuit.zip
BOM_Fanyi Education - Coin Detection Circuit.xlsx
94437
ESP32S3 drives ST7789/ST7735/ILI9341 screens
This program implements the ESP32S3 to drive the screens of ST7789/ST7735/ILI9341, controlling these LCD screens via LVGL to display images, text, and other information.
Connecting the screen using DuPont wires is too cumbersome, so I drew a simple driver board.
**ST7789 physical driver effect**
![0aa.png] **ST7735 physical driver effect**
![1aa.png] **ILI9341 physical driver effect**
![2aa.png]
ili9341.mp4
st7789v3.mp4
st7735.mp4
project_Lvgla-drivers.zip
project_Lvgla - copy.zip
main.c
PDF_ESP32S3 driver ST7789-ST7735-ILI9341 screen.zip
Altium_ESP32S3 driver for ST7789_ST7735_ILI9341 screen.zip
PADS_ESP32S3 driver for ST7789_ST7735_ILI9341 screen.zip
BOM_ESP32S3 driver for ST7789_ST7735_ILI9341 screen.xlsx
94439
Resistance comparison test
Compare the resistance values
The LM393 dual voltage comparator is used to detect the resistance value under test. When the voltage at the non-inverting input (IN+) is higher than the voltage at the inverting input (IN-), the output (OUT) will be high; conversely, when the voltage at the non-inverting input is lower than the voltage at the inverting input, the output will be low. The current circuit's non-inverting input (IN+) is input via a voltage divider from the sampling resistor and compared with the resistance value under test (IN-). When the resistance value under test is less than the sampling resistance value, a Darlington relay is driven to output a value.
This can be used for quickly screening products with resistance values ​​within a suitable range.
PDF_Resistor Size Comparison Test.zip
Altium_resistance size comparison test.zip
PADS_Resistor Comparison Test.zip
BOM_Resistor Size Comparison Test.xlsx
94440
potentiometer lamp ring
LED potentiometer ring based on STC8G microcontroller
[Bilibili] https://b23.tv/aceiFyY
The LED driver is TM1637, and the main controller is STC8G1K08A.
**Important!** The LED package is reversed!
upper_video_1712738824945784.MP4
code.7z
PDF_PotentitlerLampRing.zip
Altium_potentiometer lamp ring.zip
PADS_PotentialistorLampRing.zip
BOM_PolypotentiometerLampRing.xlsx
94441
Solar MPPT power panel
This is a solar power module based on the SN3722.
The CN3722 (Note 1) is a PWM buck charging management IC that can be powered by a solar cell and features solar cell maximum power point tracking. The CN3722 is ideal for charging single or multi-cell lithium-ion or lithium iron phosphate batteries, offering advantages such as small package size, fewer external components, and ease of use. The CN3722 features constant current and constant voltage charging modes, making it ideal for charging lithium-ion or lithium iron phosphate batteries. In constant voltage charging mode, the constant voltage is set by an external resistor divider network; in constant current charging mode, the charging current is set by an external resistor. For deeply discharged batteries, when the battery voltage is below 66.7% of the set constant voltage, the CN3722 trickles the battery with 15% of the set constant current. During constant voltage charging, the charging current gradually decreases, and charging ends when the charging current decreases to 9.5% of the set constant current. When the input power supply fails or the input voltage is lower than the battery voltage, the CN3722 automatically enters a low-power sleep mode. Other features include input low voltage latch-up, battery temperature monitoring, battery overvoltage protection, and charging status indication. The CN3722 is packaged in a 16-pin TSSOP package.
PDF_Solar MPPT Power Board.zip
Altium_Solar MPPT Power Board.zip
PADS_Solar MPPT Power Board.zip
BOM_Solar MPPT Power Board.xlsx
94442
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 01:31:10
