2SFm769
240131_Adjustable Power Supply Based on XL6019 and XL4015 V1.0_Open Source
This version is an experimental board with a total of 4 power outputs. The recommended power input is +12V.
(PS: Please ignore the background music in the video.)
8e754d14bcfe7fca7e91a4d9fdfd9235.mp4
PDF_240131_Adjustable Power Supply Based on XL6019 and XL4015 V1.0_Open Source.zip
Altium_240131_Adjustable Power Supply Based on XL6019 and XL4015 V1.0_Open Source.zip
PADS_240131_Adjustable Power Supply Based on XL6019 and XL4015 V1.0_Open Source.zip
BOM_240131_Adjustable Power Supply Based on XL6019 and XL4015 V1.0_Open Source.xlsx
96163
VAST Sound Switch
COB LED Strip Sound-Controlled Dimming Controller Based on SU-03T
A 12V power supply scheme is selected, and the COB LED strip is also 12V. A maximum output of 3A is recommended, which translates to a 528-LED LED strip no longer than 3 meters in length (actual testing shows that a 1-meter strip with 528 LEDs directly draws approximately 1.13A, which decreases to 1.08A after passing through the MOSFET and including the controller).
Regarding the power supply interface, two options are provided: MX235 and a DC socket. The project uses a 6-pin external and 2-pin internal DC socket, which can be replaced according to your power plug model. The middle pin is the positive power terminal.
February 1st.mp4
Voice-activated dimmer - Button^Voice-activated dimmer - 1.STL
Voice-activated dimmer - Base case^Voice-activated dimmer - 1.STL
Voice-activated dimmer - Cover^Voice-activated dimmer - 1.STL
PDF_VAST Sound Switch.zip
Altium_VAST Sound Switch.zip
PADS_VAST Sound Switch.zip
BOM_VAST Sound Switch.xlsx
96164
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 18:43:12
