96jnsaPo
PD Adjustable Power Supply
This PD decoy with adjustable voltage levels, based on the CH224K, is compact and
supports 3.3V (low current), 5V, 9V, 12V, 15V, and 20V outputs. Output levels
can be selected via a DIP switch, with
an LED indicator for the output level.
Multiple connection terminals are supported,
and components can be reduced or removed as needed.
PDF_PD Adjustable Power Supply.zip
Altium_PD Adjustable Power Supply.zip
PADS_PD Adjustable Power Supply.zip
BOM_PD Adjustable Power Supply.xlsx
96536
DAPLINK to Type-C connector (for bicycle breathing light project)
Connectors for the bicycle breathing light project
Connecting the Type-C D+ and D- pins to SWD and SCK allows for the creation of a debugging interface via Type-C, suitable for debugging in narrow or inconvenient areas. (Supported for bicycle breathing light project)
Note: Board thickness 0.8-1.0mm.
Project link: https://oshwhub.com/ghgjkh/hu-xi-deng-v2
PDF_DAPLINK to Type-C Connector (for bicycle breathing light project). zip
Altium_DAPLINK to Type-C connector (for bicycle breathing light project). zip
PADS_DAPLINK to Type-C connector (for bicycle breathing light project). zip
BOM_DAPLINK to Type-C Connector (for bicycle breathing light project).xlsx
96537
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 13:02:52
