6ISpVZRJDF
Color IC
JLCPCB's color screen printing on IC
cards is so beautiful!
3*5mm cards are soldered horizontally, and 5*8mm cards are soldered prone.
PDF_Color IC.zip
Altium_Color IC.zip
PADS_Color IC.zip
BOM_Color IC.xlsx
97002
CANtext-PCB
This project is the hardware component of the CANtext open-source project. For more details, please visit the CANtext open-source project website: http://www.cantext.cn/
The CANtext open-source project is a streamlined yet powerful open-source USB-to-CAN converter built on the Xiaohua Semiconductor HC32F460 microcontroller with an ARM Cortex-M4 core. CANtext creates a virtual serial port on the PC, allowing users to send data in visible string (ASCII) format via a serial port assistant or the operating system's built-in serial port driver. CANtext receives the data, parses it into CAN frames, and then sends them to the CAN bus. Simultaneously, CANtext detects data on the CAN bus and packages it back to the PC via the serial port.
The CANtext open-source project provides an open-source circuit board (CANtext-PCB), open-source PC software (CANtext_PC), and open-source firmware (CANtext_Firmware). You can easily download the source code and circuit diagrams from the open-source website for learning. Official website: www.cantext.cn
PDF_CANtext-PCB.zip
CANtext-PCB V0.21_CANtext V0.2.schdoc
PADS_CANtext-PCB.zip
BOM_CANtext-PCB.xlsx
97003
TPA3255 Dual 325W Stereo Digital Amplifier
It has been verified that the main chip uses TI's TPA3255. It features dual 325W stereo speakers. The board outline and layout are basically the same as the standard models on Taobao; you can search and compare them yourself.
This amplifier board has been verified, and the current processing effect is quite good. At maximum volume, you need to hold it very close to your ear to hear even a slight background noise. The main chip is the TI TPA3255. It features dual 325W stereo. The preamplifier is designed with a 10x amplification factor, which can be modified. The BOM file is based on the PCB specifications. Replaceable op-amps can achieve your desired effect. There is currently only one discussion group, which integrates all categories into one group. QQ: 1140901999
TPA3255-315w+315w(ascii).rar
PDF_TPA3255 Dual 325W Stereo Digital Amplifier.zip
Altium_TPA3255 Dual 325W Stereo Digital Amplifier.zip
PADS_TPA3255 Dual 325W Stereo Digital Amplifier.zip
BOM_TPA3255 Dual 325W Stereo Digital Amplifier.xlsx
97004
Light control lights
Light-controlled lights turn off during the day and automatically turn on at night.
A simple electronic design suitable for beginners:
a small light controlled by a photoresistor that
turns off when there is light and automatically turns on when the light is dim.
ebd459ca2661d76b5633cfb4aeec5479.mp4
PDF_LightControlLamp.zip
Altium_LightControl.zip
PADS_LightControl.zip
BOM_Light Control Light.xlsx
97005
STM32H723ZGT6 High-Performance Color Screen Printed Development Board
Embrace the STM32H723ZGT6 high-performance color silkscreen development board. Who wouldn't want a development board that looks good and performs well?
![3D_PCB2_2023-10-25.png]
PDF_STM32H723ZGT6 High-Performance Color Silkscreen Development Board.zip
Altium_STM32H723ZGT6 High-Performance Color Silkscreen Development Board.zip
PADS_STM32H723ZGT6 High-Performance Color Silkscreen Development Board.zip
97006
STM32F103 Balance Scooter Third Edition PRO
A self-balancing scooter control board based on STM32F103C8T6.
Main Control Chip: The STM32F103 was chosen as the main control chip. The STM32F103 is a microcontroller based on the ARM Cortex-M3 core, featuring abundant peripheral resources and powerful computing capabilities, making it suitable for controlling the movement of the self-balancing scooter.
Driver Chip: The TB6612 was chosen as the driver chip. The TB6612 is a dual-channel DC motor driver chip, capable of providing sufficient current and voltage to drive the scooter's motors. It features overload protection and current detection functions, effectively protecting the motor and circuitry.
Sensors: Self-balancing scooters typically use accelerometers and gyroscopes to sense the tilt angle and attitude of the vehicle for balance control.
Power Supply: Self-balancing scooters require a stable and reliable power supply system. A lithium battery can be selected as the main power source, with a TPS5450 voltage regulator chip for power supply.
Motors: Self-balancing scooters typically require two motors to drive the wheels. A brushless DC motor can be selected as the drive motor, featuring high efficiency, low noise, and long lifespan.
PDF_STM32F103 Self-Balancing Scooter Third Edition PRO.zip
Altium_STM32F103 self-balancing scooter third edition PRO.zip
PADS_STM32F103 Balance Scooter Third Edition PRO.zip
BOM_STM32F103 Self-Balancing Scooter Third Edition PRO.xlsx
97007
Serial communication module based on STM32F103
This module can be used to display serial port data. Currently, it can only display a single line, enable and stop receiving, and reset. The baud rate is 115200 and cannot be modified. The display currently has bugs and will be improved in future updates.
This module can be used to display serial port data. Currently, it can only display one line, enable and stop receiving, and reset. The baud rate is 115200 and cannot be modified. The display has bugs, and it will be improved later, for example, by changing the baud rate. Currently, the OLED driver uses 1306, and it seems that different OLED drivers cannot be used simultaneously. When sending data, a newline character "
" needs to be added at the end for the data to be displayed. For example, an example of sending the character '1' via serial port using STM32 is as follows: `printf("1
");` The project is a HEX file.
Hardware IIC.hex
PDF_Serial Port Interaction Module Based on STM32F103.zip
Altium_serial port interaction module based on STM32F103.zip
PADS_Serial Port Interaction Module Based on STM32F103.zip
BOM_Serial Port Interaction Module Based on STM32F103.xlsx
97008
Power supply module (stable 3.3V)
DC-DC step-down module, input 4.5V-16V, output 3.3V/3A, can power a microcontroller.
This project is a DC-DC step-down module with an input of 4.5-16V and an output of 3.3V, which can directly power a microcontroller.
The test video is available on Bilibili: https://www.bilibili.com/video/BV1z34y1c76R/?spm_id_from=333.999.0.0&vd_source=8feac9e8c73c90f7dd3c70ab08350e52
PDF_Power Module (Stable 3.3V).zip
Altium power module (stable 3.3V).zip
PADS_Power Module (Stable 3.3V).zip
BOM_Power Module (Stable 3.3V).xlsx
97009
CM1033_ETA3000_Three-cell lithium-ion battery series protection balance board
This is a verification board for a CM1033_ETA3000 three-cell lithium-ion battery series protection balance board. It works normally, but hasn't been thoroughly tested (due to lack of resources).
When using the ETA3000, please note the following:
1. Before installing the batteries, connect them in parallel to balance the voltage. Installing batteries with significantly different voltages will damage the chips.
2. When installing the batteries, connect the EN pin to the BATAN pin with a jumper wire. Do this for each battery. After installing the batteries, remove the jumper wire. Installing batteries while in operation will damage the chips.
3. When removing batteries, also connect the EN and BATAN pins with a jumper wire; otherwise, the chips will damage, especially if BATP and BATAN are connected. Directly removing BATC will definitely cause damage.
4. Do not touch the chips unnecessarily. The image below shows a chip damage caused by a finger probe, which also burned the board.
I hope everyone can successfully build their boards without damaging chips or burning batteries, and that everything works normally.
PDF_CM1033_ETA3000_Three-cell lithium-ion battery series protection balance board.zip
Altium_CM1033_ETA3000 Three-Cell Lithium-ion Battery Series Protection Balance Board.zip
PADS_CM1033_ETA3000_Three-cell lithium-ion battery series protection balance board.zip
BOM_CM1033_ETA3000_Three-cell lithium-ion battery series protection balance board.xlsx
97010
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-24 07:16:04
