Two-stage motor speed regulation main circuit and level indication circuit
Source: InternetPublisher:难得正经 Keywords: Main circuit level indication circuit motor speed regulation BSP Updated: 2021/03/28
The circuit is shown in Figure 3-178. It is used to wither the torque motor on the continuous casting machine. The circuit
consists of a main circuit, a trigger circuit, a manual control and automatic control signal circuit and a level indicator.
① Continuous casting machine motor speed regulation main circuit and level indication circuit (Figure 3-178)
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- What is a RADAX motor?
- How to set up a cheap beam break sensor control distance scene using a reflector
- A small improvement to the temperature and water level indicator alarm
- Using P110C to control 6 DC motors simultaneously
- Add one more component to improve the phase failure protection function
- Design and manufacture of three-phase motor protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- base amplitude modulation circuit
- ring amplitude modulation circuit
- common emitter amplifier circuit
- Second-order active band-stop filter circuit
- color discrimination circuit
