Home > Control Circuits >Timing Circuits > Voltage regulation and timing dual-purpose controller
Source: InternetPublisher:念念Brown Keywords: Timing control NE555 Updated: 2024/10/31
This is a voltage regulation and timing dual-purpose controller with simple circuit, easy production and convenient use. Its specifications are: voltage regulation range 30-215V AC, timing 5-60 minutes, power 500W. It can regulate voltage (dimming, temperature adjustment, speed adjustment) or time off various household appliances. (Tip: The "voltage regulation" function must not be used for appliances with switching power supply! Such as computers, color TVs, mobile phone chargers, etc.)
How it works
Timer
The circuit principle of the dual-purpose controller is shown in Figure 1. When the voltage regulation and timing selection switch S2 is set to 1, NE555 and S, C3, RP2 and VS form a timing control circuit. When in use, press AN, C3 quickly discharges through R2 and AN. At this time, the ② and ⑥ terminals of NE555 are high level, the ③ terminal outputs a low level, the bidirectional thyristor VS is turned on, and the output socket CZ has a voltage output. The DC power supply charges C3 through RP2 and R3. After C3 is fully charged, the voltage of the ② and ⑥ terminals of NE555 is reduced to 1/3 of the DC power supply voltage. At this time, NE555 is set, the ③ terminal outputs a high level, VS is cut off, and CZ has no voltage output.
When switch S is set to 2, NE555 and RP1, R1, C2, etc. form a trigger pulse generating circuit. Terminal ③ of NE555 outputs a trigger pulse with a frequency of about 13Hz and an adjustable duty cycle. The width of the trigger pulse can be changed by adjusting RP1, and then the pulse is used to control the conduction angle of VS, so that the output voltage on CZ changes with the change of the conduction angle, thereby achieving the purpose of voltage regulation. The function of VD1 is to keep the oscillation period unchanged while changing the trigger pulse width when adjusting RP1. C5, VDW, and VD2 form a step-down and rectifier circuit to provide NE555 with a DC working voltage of about 12V. C5 is a step-down capacitor. R2 and R4 are current limiting resistors.
Component selection and production
The components list is shown in the table below.
serial number
name
model
quantity
R1
resistance
47K
R2
resistance
100Ω
R3
resistance
100K
R4
resistance
470Ω
RP1
Potentiometer
1M Linear Potentiometer
RP2
Potentiometer
3.3M Linear Potentiometer
C1
Electrolytic Capacitors
470uF
C2
Polyester capacitor
0.1u
C3
1000uF
C4
Polyester capacitor
0.01u
C5
Metallized capacitors
0.47uF Withstand voltage ≥400V
VD1
Switching diode
IN4148
VD2
Rectifier diode
IN4007
VDW
Zener diode
12V
VS
Bidirectional thyristor
3A 600V
IC
Time base circuit
NE555
Transfer switch
1×2 small toggle switch
CZ
Power outlet
10A 250V
RP2 is used to adjust the timing time. After installation, the scale can be marked on the outer shell according to the relationship between time and angle.
After the dual-purpose controller is installed, it can generally work normally without debugging as long as genuine components that meet the requirements are selected and installed correctly.
