Control circuit for the auxiliary engine to stop after the main engine has stopped
Source: InternetPublisher:笑流年 Keywords: Control circuit BSP motor Updated: 2021/04/28
The circuit is shown in Figure 3-84. As can be seen from the figure, the two motors can be started separately. But only when
the stop button SBz of the main machine (Ml) is pressed (after the contactor KMi is released), and then the stop button SB4 of the auxiliary machine (Mz) is pressed, M2 can be
stopped. SBs is the emergency stop button. When two motors need to be stopped at the same time, just press SBs.
- DIY a simple fire alarm
- Design of an autonomous plant watering system using ATtiny85
- Peripheral circuit of automotive motor controller power supply chip
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- A small improvement to the temperature and water level indicator alarm
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Set timing circuit when power is on
- Voice controlled flash LED light circuit diagram
- Peanut and melon seeds roasting machine circuit
- Crop anti-frost circuit
- Particle clogging alarm circuit of wheat seeder
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit b
- AC voltmeter
- base amplitude modulation circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
