CD4511 digital tube driver wiring circuit diagram
Source: InternetPublisher:桂花蒸 Keywords: Wiring circuit diagram digital tube driver CD4511 Updated: 2020/03/05
CD4511 is a CMOS BCD-latch/7-segment decoder/driver, used to drive the BCD code-seven-segment code decoder of common cathode LED (nixie tube) display. Its CMOS circuit with BCD conversion, blanking and latch control, seven-segment decoding and driving functions can provide large source current. Can directly drive common cathode LED digital tube.
The following is the CD4511 digital tube drive principle circuit diagram . It is CD4511 that realizes the parallel interface method between LED and microcontroller.
![CD4511 digital tube driver wiring circuit diagram](http://www.eeworld.com.cn/circuit/upload/9876a4cfffd269ae572787f552b00a42/01bf8eb2939af8752eb4fbb821d3138f.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to Make a Soft Latch Circuit
- Energy-saving motorcycle rectifier regulator
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- Voltage-current converter constructed with XTR110
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- Detailed explanation of mobile phone charger circuit diagram
- Radial wiring power supply circuit c
- Radial wiring power supply circuit a
- Automated instruments use filters to resist interference wiring
- Connection between PLC and frequency converter a
- Lightning protection wiring of generator-transformer unit
- Roof lightning protection network wiring
- Wiring c when the leakage protector supplies power to single-phase loads in the TN system
- Wiring b when leakage protector supplies power to single-phase load in TN system
- Wiring c when the leakage protector in the TN system supplies a three-phase balanced load
- Wiring for single-phase power meter to measure single-phase current power
