Voltage transformer circuit a
Source: InternetPublisher:武林萌主 Keywords: Voltage transformer BSP instrument Updated: 2020/01/04
Voltage transformers are widely used in power systems
and are divided into two types: electromagnetic type and capacitive type
. The primary side of the voltage transformer is connected to
the high voltage to be measured, and the voltage on the secondary side is generally
loov, which is used for instrument indication or as a starting power supply for protective action
devices. When using a voltage transformer,
the measuring instrument circuit can be isolated from the high-voltage
circuit
, thus ensuring
the safety of people and electrical equipment. The appearance of the voltage transformer
is shown in Figure 5-12a.
Voltage transformer is a small high-voltage transformer, which can be divided into single-phase and three-phase voltage transformers. Used on high-voltage power lines, the wiring line
is shown in Figure 5-12b. When using voltage transformers, you should pay attention to the following aspects.
1) The secondary side of the voltage transformer is never allowed to be short-circuited, and it can only be put into operation after passing the withstand voltage test.
2) Frequently check the voltage transformer for oil shortage, oil leakage, and whether the oil-porcelain bushing is cracked or damaged and other unsafe factors.
- Make a Economical and Practical Rectifier Voltmeter
- Simple electric tachometer
- Multi-speed current test circuit of transistor HFE
- Digital strain gauge circuit using MAX1492/MAX1494
- Making an Induction Electroscope Using CD4069
- Electric vehicle luminous voltmeter with undervoltage alarm
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Geiger counter circuit diagram
- Typical two-stage low-pass filter circuit
- voltage amplifier circuit
- Set timing circuit when power is on
- strain sensor
- Electronic anti-asthma circuit
- soil content measurement circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Voltage-controlled voltage source second-order band-pass filter circuit
- superheterodyne radio circuit
- color discrimination circuit
- High and low frequency signal generator circuit
- Digital stopwatch display circuit
